Carb Question Old School or New #1187187
02/27/12 04:03 PM
02/27/12 04:03 PM
White Hall, Maryland
MD72 Offline OP
MD72  Offline OP
I have a 318 done .30 over with a mild cam and a stock 2 bbl. I want to put on an LD4B that I have. What carburetor should I use?
Re: Carb Question Old School or New [Re: MD72] #1187188
02/27/12 04:14 PM
02/27/12 04:14 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Edelbrock thunder series 600. Once it set up it will work for ever. Remember not more that 5.5 pounds of fuel pressure. If it is hard to start after sitting at the gas station to fill up, you need the pressure regulator. Summit sells a couple of different ones( ie. Mr.Gasket). Holley 600 will perform slighly better, but you will be tinkering with it often.
Re: Carb Question Old School or New [Re: babarracuda] #1187189
02/27/12 05:45 PM
02/27/12 05:45 PM
dogdays Offline
dogdays  Offline
I am using a Holley 1850 600cfm on my 318. The only tinkering I have had to do involves jetting it for altitude and with the new blue gaskets it is a breeze. Either carb will work well once it is set up. Both carbs don't like too much fuel pressure.
I am going to try out a 570 Street Avenger, I like it better because it has two metering blocks so you can change jets in primary and secondary bowls. The 1850 has a front block and rear plate, although there are kits to use jets in the back.
R.
Re: Carb Question Old School or New [Re: dogdays] #1187190
02/27/12 06:00 PM
02/27/12 06:00 PM
MD72 Offline OP
MD72  Offline OP
Can I keep the stock fuel pump?
Re: Carb Question Old School or New [Re: MD72] #1187191
02/27/12 06:20 PM
02/27/12 06:20 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
will the ld340 ports line up with the 318 heads?
Re: Carb Question Old School or New [Re: MD72] #1187192
02/27/12 08:55 PM
02/27/12 08:55 PM
My OE 318 fuel pump puts out over 7 psi EDIT that was checked w the psi side of a round hand held vacuum gauge and I do not know how dead on they are
Re: Carb Question Old School or New [Re: RapidRobert] #1187193
02/27/12 09:03 PM
02/27/12 09:03 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I cannot say this enough...if you are going to invest in a new Holley style carb. do yourself a favor and get one with removable air bleeds. You will thank yourself once you get it dialed in.
Re: Carb Question Old School or New [Re: Jeremiah] #1187194
02/27/12 09:09 PM
02/27/12 09:09 PM
are there any other adjustable (sub)systems I should have in a carb purchase other than the norm
Re: Carb Question Old School or New [Re: lewtot184] #1187195
02/28/12 04:09 AM
02/28/12 04:09 AM
the LD340 ports are quiet a bit bigger than the ports on most 318 heads, I would not try that unless you want to port the 318 heads bigger than they are now
Re: Carb Question Old School or New [Re: Cab_Burge] #1187196
02/28/12 04:20 AM
02/28/12 04:20 AM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
I got a 625 cfm Carter AVS for $80 off of eBay and rebuilt it with a kit from Mike's for $40. I just fired it up tonight on top of a standard Performer intake and it works great. 85% of a new Thunder AVS for a third of the price. Stupid easy to tune too.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Carb Question Old School or New [Re: MD72] #1187197
02/28/12 08:48 AM
02/28/12 08:48 AM
IN
ahy Offline
ahy  Offline
IN
The stock pump should work fine. The Edelbrock will need a regulator though; the needle won't shut off the fuel flow with over about 4.5 lb pressure. The Holly regulator is best.
Re: Carb Question Old School or New [Re: RapidRobert] #1187198
02/28/12 12:50 PM
02/28/12 12:50 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I am not sure I understand your question Robert.
