Re: milidon gear drive
[Re: Dodgem]
#1187146
02/27/12 05:25 PM
02/27/12 05:25 PM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
No there are no marks on it
My older one has marks. Still, the holes are all enlarged for offset bushings so it still needs to be dialed in.
To the OP, what's the big deal to dial it in ?!?!? Especially on a hemi even with the heads on!
[Re: Stanton]
#1187147
02/27/12 06:02 PM
02/27/12 06:02 PM
Posts: 236 Maryland
cudaboone
Maryland
Can i line up the marks on my present chain and then install the gear drive and be pretty close?
[Re: cudaboone]
#1187149
02/27/12 08:16 PM
02/27/12 08:16 PM
Posts: 18,157 Mass
DAYCLONA
Mass
That's just "back yard" hacking, do it right, spend the money, buy a degree wheel, a dial indicator/stand, and know where your cam "IS".....You'd be surprised how much some cams, and/or drives are 'out".....get peak performance out of your motor,...if you don't, then you'll be back here asking why your engine falls on it's face when you get on it...
