727 BB TRANNY LEAK #1187078
02/27/12 12:15 PM
02/27/12 12:15 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
Ok I have tried everything I can think of besides changing the pan. My Tranny pan leaks at the front corner of the passenger side. I tried silicone with rubber gasket, cork and even the new gasket from the dealer for a RH46 and still leaks. I'm at a loss. Anybody had this problem? What should I try next? Is it the pan? or the exaust heating the gasket? or is it some kind of ventilation that's not hooked up?
Re: 727 BB TRANNY LEAK [Re: roy2345] #1187079
02/27/12 12:45 PM
02/27/12 12:45 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
Hi,
That's right below where the dipstick tube is located. Other members have suggested cleaning the entire area of the transmission, i.e. brake clean, then with it dry sprinkle baby powder. The powder will show the fluid's path.
I would check the o-ring on the dipstick tube, cracks on the end dipstick tube, etc. If it looks good, put a fair amount of gasket RTV around the o-ring, put the tube back in and smear the RTV down around the tube where it meets the case to seal it.
Mike.
Re: 727 BB TRANNY LEAK [Re: moparmike1] #1187080
02/27/12 08:00 PM
02/27/12 08:00 PM
BDW Offline
BDW  Offline
Check here, pivot rod had me running in circles for awhile!
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: 727 BB TRANNY LEAK [Re: BDW] #1187081
02/27/12 08:37 PM
02/27/12 08:37 PM
Nanaimo, BC
N
NOrrTH Offline
NOrrTH  Offline
N
Nanaimo, BC
I had a couple of leaks. Turned out someone put the wrong gasket on although it looked right, on VERY close inspection you could see it wasn't a perfect fit.
They replaced the O-ring and threw on a new pan with the correct gasket and all is golden.
'71 GTX N96 auto 3:55 '74 Challenger 440+6 4spd 4:10 '71 Duster 340 auto 4:10
Re: 727 BB TRANNY LEAK [Re: BDW] #1187082
02/28/12 07:11 PM
02/28/12 07:11 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
I believe I found the leak. It's on top of the gear shift lever. And then Its running across the tranny. This lever mechanism is near the neutral switch sensor. How do I fix that?
Re: 727 BB TRANNY LEAK [Re: roy2345] #1187083
02/28/12 08:11 PM
02/28/12 08:11 PM
BDW Offline
BDW  Offline
Sounds like the selector shaft seal, very common.
