Page 2 of 6 1 2 3 4 5 6
Re: ever hear a sound like this? [Re: moparacer] #1186570
02/26/12 08:53 PM
02/26/12 08:53 PM
Marysville, O-H-I-O
70Cuda383 Offline OP
Marysville, O-H-I-O
Did you pull the belt off and try it?
I swear I have had idler pulleys screech just like that.
I appreciate the help guys, but if you're not going to read what I have and have not done, then please don't bother. For the third time in this thread, yes I tried it with the belt off
**Photobucket sucks**
Re: ever hear a sound like this? [Re: emarine01] #1186571
02/26/12 08:55 PM
02/26/12 08:55 PM
my own world
theraif Online tonguue
theraif  Online Tonguue
my own world
is that one engine the wouldn't go above 3000 rpms?
Re: ever hear a sound like this? [Re: theraif] #1186572
02/26/12 09:20 PM
02/26/12 09:20 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
No. This one was reving great on the first fire-up. Straight to 5,000 rpm. But after headers were glowing a little, the guy who writes the EFI tune said that it's almost always from cam timing when the headers get hot like that,so i put a degree wheel and found that the dots lined up on this one put me at 116 installed intake centerline. Cam is on a 114 LSA, but is apparently supposed to be installed at 110, So I bumped it ahead 6 degrees.
The other engine I lined up the dots, but missed the correct dot, and ended up about 35 degrees off. THAT one wouldn't go over 3 grand, but is a-ok now
Needless to say, between these 2 trucks, it's been a rough couple weeks! And after these 2 engines, NEVER again will I just line up the dots!!
Re: ever hear a sound like this? [Re: 70Cuda383] #1186573
02/26/12 09:29 PM
02/26/12 09:29 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
almost sounds like the push rods are rubbing in the heads,is there enough clearence?
Re: ever hear a sound like this? [Re: 2QUICK4U] #1186574
02/26/12 09:39 PM
02/26/12 09:39 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
I thought so, but will double check.
The heads do have guide plates though and I remember them looking tight in places, but it didn't feel like it was rubbing anywhere guess I can pull the pushrods out for signs of wear/rubbing
Re: ever hear a sound like this? [Re: 70Cuda383] #1186575
02/26/12 09:49 PM
02/26/12 09:49 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Well, did you pull the valve covers yet?
Re: ever hear a sound like this? [Re: Hot 340] #1186576
02/26/12 09:50 PM
02/26/12 09:50 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
Tomorrow
Family time tonight. Just getting ideas of things to look at tomorrow
Re: ever hear a sound like this? [Re: 70Cuda383] #1186577
02/27/12 04:34 PM
02/27/12 04:34 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
Ok, here's what I've found so far...
All rockers are getting oil it takes a few minutes of idle time, but eventually, oil flows through the rocker, fills up the middle and it spills over the roller tip and all over the valve.
pushrods do contact guide plates in a few spots, and have worn the black finish off in a few spots on the pushrods, but the metal is not galled up, there is no wear into the metal at all, it's still perfectly smooth to the touch. There is no room to adjust the guide plates, only option is to open the plates up a little bit so they don't rub.
LOTS of clearance through the head for the pushrods. holes are probably 7/16 or 1/2, and the pushrods are only 3/8, and are not anywhere near contacting the head anywhere, and there are no marks on the pushrods to indicate rubbing on the heads
removed the valve spring on the #2 exhaust valve, the valve is..."Sticky" is the best that I can explain it. I can move it up and down without much effort, but they do feel like they stick a little bit. without the valve spring on, I can let go of the valve, and it stays where I put it, it does not fall through at all.
--is that too tight? or "just right"?
there is wear on the valve stem from the roller rocker, indicating that the valves do not spin. should they spin like lifters do? I thought I've heard somewhere about valves rotating, but I don't see anything on this that would force them to rotate, especially with a roller rocker.
I'm going to open up the guide plates, maybe check a few more valves, and see what happens.
Re: ever hear a sound like this? [Re: 70Cuda383] #1186578
02/27/12 04:58 PM
02/27/12 04:58 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I heard this exact same sound years ago with a Mallory Unilite distributor. The rotor was sitting too low and rubbing the distributor body....not sure if this is your issue, but the sound is the same squeaking I remember.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: ever hear a sound like this? [Re: FlyFish] #1186579
02/27/12 05:05 PM
02/27/12 05:05 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
stock distributor, EFI engine, but I'll check the rotor again. there's really nowhere for it to rub though, as there's the cam position sensor that's on a plate that's down into the body of the distributor, then the shaft sticks up 3 or 4 inches, and the rotor is up on top. there's nothing in between like on an electronic ignition distributor with the magnets and pick-ups etc.
Re: ever hear a sound like this? [Re: 70Cuda383] #1186580
02/27/12 06:25 PM
02/27/12 06:25 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
did it again without the valve seal this time, and the stickiness is gone, but it's still..."firm" it moves smoothly, but it doesn't drop down under it's own weight.
Re: ever hear a sound like this? [Re: 70Cuda383] #1186581
02/27/12 07:57 PM
02/27/12 07:57 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I had a few GM engines with front cover oil seals that squeaked like your noise. Sometimes spraying the seal will temporarily quiet it to isolate the noise. I've had a few of them. Also had front axle seals with a similar noise.
Doug
Re: ever hear a sound like this? [Re: dvw] #1186582
02/27/12 10:18 PM
02/27/12 10:18 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I'm thinking thvalve should drop from it's own weight , so the guide is definitely tight......that dimension shrinks up as the motor builds heat.
Whether it is too tight or not I don't know.
Or whether it would sound like that or not.
I think I'd be pulling the heads.
Re: ever hear a sound like this? [Re: tubtar] #1186583
02/28/12 09:57 AM
02/28/12 09:57 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
IMO the guides are fine, you don't want them loose. 1.6 rockers take alot of clearancing to work right and cause extra wear, like I said in the past.
I don't see how you can set the valve lash accuratly with the engine running, almost impossible . IMO
I set mine with the intake off so I can see what I'm doing.
Good luck with it.
I now listened to your video, It sounds like the pushrods rubbing against the guide plates?
Can't believe Mopar went to stud mounted rocker arms and guide plates! chevy... I thought shaft mounted rocker arms was better??
Re: ever hear a sound like this? [Re: tubtar] #1186584
02/28/12 09:58 AM
02/28/12 09:58 AM
Marysville, O-H-I-O
Marysville, O-H-I-O
Hmm...ok.
I'll check a set of stock magnum heads with 70K miles on them that I have here, and see how they feel so I have something to compare to, see if the valve falls through on it's own.
I think at this point, I'm going to finish trying to open up the pushrod guide plates so they don't rub, and run it, if it's still squeeks, then I'll pull the motor out, pull the heads and take them in for guide work, then pull the crank out and do the cam bearings, and then put it back together again.
I hate re-work!
Re: ever hear a sound like this? [Re: 70Cuda383] #1186585
02/28/12 10:23 AM
02/28/12 10:23 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
pull the valve covers and make sure your rollers clear. I had a set rubbing a set of moroso's...didn't sound like that but it was annoying.
Coming soon!!!!
Re: ever hear a sound like this? [Re: Mr.Yuck] #1186586
02/28/12 11:27 AM
02/28/12 11:27 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Wow. Sounds like there is a bird caught in there somewhere!
Only time I have encountered anything similar was with a 150,000 mile fan clutch, that would would lock up intermittantly....but you eliminated that kind of issue long ago.
I think you're looking the right place (stem to guide)
As a union trained master mechanic/machinist, tool and die maker with 30 years experience explained to me:
As a general rule of thumb, .0008" is a magic number as far as normal human, layman capability to "feel" clearance goes.
Clean, lightly lubed, near room temp, a wrist pin or a valve will usually fall through the hole under it's own weight at .0008".
If it wiggles, either it's looser than .0008" and/or the parts have an irregular shape (not straight/round).
If you have to push it through the hole with any pressure, it's going to be tighter than .0008" and/or the parts have an irregular shape (not straight/round).
That might sound silly but I have put it to the test, and have found it to always be correct.
I believe you're going to find the actual clearance is .0007, 7 ten thousandths of an inch or smaller.
Personally I want .001 to .0025-ish stem to guide for most street apps
To me, tight guides are an accident waiting to happen (what happens when a valve sticks open?) and could cost you an engine
Rich H.
Esse Quam Videri
Re: ever hear a sound like this? [Re: ZIPPY] #1186587
02/28/12 12:14 PM
02/28/12 12:14 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I have heard a similar noise from a chain tensioner in the timming set dry, dont know if your running that or not. Also have heard the converter bolts being a tad slightly loose, and causing a swueak. That was in a 4x4 truck, and he used lock tight and didnt really tighten them up good and tight, and they didnt bounce and knock, but squeaked a tad at idle.
Im sure you greased the oil seals before putting it together, or at least lubed them a bit, cause you would have burned the seal up if it was that dry and have oil everywhere. Also have replaced a few OE magnum distributors for a partially siezed/bent shaft causing the same noise.
Good luck, and BTW did ya take the drive belt off???
LOL
Kasey
Re: ever hear a sound like this? [Re: Moparnut426] #1186588
02/28/12 03:50 PM
02/28/12 03:50 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
LOL
Kasey
Dam you ! you made me get my keyboard wet !! LMAO
Re: ever hear a sound like this? [Re: VernMotor] #1186589
02/28/12 06:14 PM
02/28/12 06:14 PM
P
Paul_Fancsali Offline
P
While you have th cap off oil the dist wick under the rotor. I had a noise like that and it was the dist itself making the squeeking. Ended up installing new bushings
