Page 1 of 6 1 2 3 4 5 6
ever hear a sound like this? #1186550
02/26/12 05:29 PM
02/26/12 05:29 PM
Marysville, O-H-I-O
70Cuda383 Offline OP
Marysville, O-H-I-O
Tomorrow I'm going to get some rubber hose and see if I can narrow down the sound. Any of you heard anything like this?
first, no, it's NOT an accessory belt/pulley issue. I removed the belt and the sound was unchanged. I hooked the belt back up to circulate water with the pump after trying it without a belt.
Details are: stock 5.9L block, stock cast crank, new rods, new pistons, everything balanced together, edelbrock heads, and 1.6 adjustable roller rockers from Hughes. cam is 220/230 @ .050 114 LSA, hardened pushrods.
I didn't notice the sound initially, had some isues on first fire-up with the headers getting hot and starting to glow faintly, looked at cam timing and found it was 6 degrees retarded (never again will I just line up the dots!!!) advanced it with a different timing set and 2 degree key so it's now at 110installed centerline the way the cam card says it should have been originally.
noticed the sound after I got the rockers re-set and started the engine back up.
pulled the distributor out and spun it around, it feels fine, smooth, no squeeks when spun by hand. pulled oil pump drive shaft and it looks normal, wear marks are dead center on the teeth of the gear, and the bronze bushing in the block looks ok, so I don't think thats worn and causing mis-alignment issues.
tomorrow I'll pull the crank position sensor and check it just to be sure it hasn't moved and is rubbing on the flexplate, maybe kill a cylinder at a time and remove intake/exhaust to see if it goes away with any one cylinder, run a compression test, leak down test, and see where I'm at.
if I can't find anything, I'll probably be pulling the intake for a visual inspection, and probably take the timing cover back off again.
any ideas on what this sound might be? aside from the roller cam and rocker arms, the internals to this engine are the same as all the other LA small blocks out there.
http://youtu.be/oYVDffxuduk
**Photobucket sucks**
Re: ever hear a sound like this? [Re: 70Cuda383] #1186551
02/26/12 06:03 PM
02/26/12 06:03 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
did u check to see if oil is getting to the top end??
Re: ever hear a sound like this? [Re: rickraw] #1186552
02/26/12 06:10 PM
02/26/12 06:10 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Kinda sounds like a dry rocker?
Yeah, it's got a smallblock.
Re: ever hear a sound like this? [Re: 340B5] #1186553
02/26/12 06:15 PM
02/26/12 06:15 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Your rocker shafts aren`t installed right and the sound is the rockers.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: ever hear a sound like this? [Re: 340B5] #1186554
02/26/12 06:16 PM
02/26/12 06:16 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
yea it sounds like something is dry. check all valvetrain and look at bushing in block for oil pump drive. maybe something rubing in the timing chain ? I have heard some strange noises out of fuel rails before also..But first hand I want to think it sounds like a dry rocker ??
Re: ever hear a sound like this? [Re: 340B5] #1186555
02/26/12 06:25 PM
02/26/12 06:25 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
I thought rocker too. Can u pull a VC and try it to see if it is louder. Then try the other vc
Old Geezer Racing
Re: ever hear a sound like this? [Re: SCATPACK 1] #1186556
02/26/12 06:30 PM
02/26/12 06:30 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
sounds bad.... I wouldn't run it too much, pull a valve cover and run the oil pump on a drill or @ least on the starter with the plugs out @ see if its oiling up top
Re: ever hear a sound like this? [Re: SCATPACK 1] #1186557
02/26/12 06:34 PM
02/26/12 06:34 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
I'll check the rockers, I THOUGHT I remember seeing oil flying everywhere when I had it running -- I actually set the valve lash with it running, based on the advice of a lot of the other Dakota guys, got the stuff close enough to run, then as it was running, tightened down the lash and locked it up solid.
I sure hope it is just the rockers somewhere though, those are easy and right up on top!
the bronze distributor bushing looked good when I looked at it with a flashlight through the hole in the block, and like I said about the distributor/oil pump drive gear, the gear mesh pattern was right in the middle of the teeth, so I don't think the bushing is worn out causing slop there, otherwise the gears wouldn't be meshing properly, right?
these are the rockers I'm running:
http://www.hughesengines.com/Index/produ...mp;partid=25423
also appear to be the same as these cheap chevy rocker arms for $100 less:
http://www.ebay.com/itm/SBC-GM-350-Chevy...ecc&vxp=mtr
Re: ever hear a sound like this? [Re: SCATPACK 1] #1186558
02/26/12 06:39 PM
02/26/12 06:39 PM
tn
robnbird Offline
robnbird  Offline
tn
sounds like a rocker but did you take all of your belts off first just to see if that stops the noise. I have heard water pump brgs make that noise also.
Re: ever hear a sound like this? [Re: 70Cuda383] #1186559
02/26/12 06:42 PM
02/26/12 06:42 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
do the heads have new guilds in them ? fresh heads ? maybe one of them is to tight ? just throwing out ideas here. new style heads so no rocker shafts right.
Re: ever hear a sound like this? [Re: VernMotor] #1186560
02/26/12 06:44 PM
02/26/12 06:44 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
brand new edelbrock heads. stud mounted rockers, oil through pushrods.
and yes, although the belt is on in the video, I removed the belt, and the noise was still there
Re: ever hear a sound like this? [Re: 70Cuda383] #1186561
02/26/12 06:51 PM
02/26/12 06:51 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well them heads are know to have to tight of guilds. OOB.. I took my apart before I put them on and check. my was ok. But I have read storys
Re: ever hear a sound like this? [Re: VernMotor] #1186562
02/26/12 06:57 PM
02/26/12 06:57 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
yea, so have I. might have just bit me in the butt, but my local machine shop shrugged and said "we run them out of the box all the time, they had problems when brand new, but they haven't had any quality problems in years."
hope it's just rockers and not the valve guides.
is there a way to easily check that without taking the heads off?
Re: ever hear a sound like this? [Re: 70Cuda383] #1186563
02/26/12 07:18 PM
02/26/12 07:18 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well if you was careful.. and you got the tools to take the springs off. you could at lease get a feel for them. lot of diff ways to do this..I would not pull the head to check it out some.
Re: ever hear a sound like this? [Re: VernMotor] #1186564
02/26/12 07:39 PM
02/26/12 07:39 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
I can use a leak down tester to pressurize the cylinder and keep the valves from dropping, right?
I have a "on head" spring compressor, ordered it for these types of heads (individual mounted rockers like on these Magnum engines) but I just haven't used it yet. what would I feel for though? just smooth movement? no binding or rubbing? how tight is "too tight"? --if the rockers all check out good...
Re: ever hear a sound like this? [Re: 70Cuda383] #1186565
02/26/12 07:53 PM
02/26/12 07:53 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
well I would roll the cy up to TDC that I was checking and put some rope in the spark plug hole to keep the valve from falling. I say this because with air in there it is holding it tight and not let it fall down a little. so you can move it. you need to be able to slide is up and down and side to side to get a feel for it to see if it is to tight. I know this is not the corrected way to check them..but will give you some idea.I mean if you got push hard or pull hard to make it move you know it is to tight.
Re: ever hear a sound like this? [Re: VernMotor] #1186566
02/26/12 08:23 PM
02/26/12 08:23 PM
PA
moparacer Offline
moparacer  Offline
PA
Did you pull the belt off and try it?
I swear I have had idler pulleys screech just like that.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: ever hear a sound like this? [Re: moparacer] #1186567
02/26/12 08:38 PM
02/26/12 08:38 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I would think if you ran it with the covers off... you would remember cleaning up the mess
Re: ever hear a sound like this? [Re: 70Cuda383] #1186568
02/26/12 08:50 PM
02/26/12 08:50 PM
I have heard exhaust leaks sqeak and chirp just like that Usually in the collectors When you got closer to the right valve cover it sounded like a part rotating and rubbing or hitting some other parts I hope not, good luck
Re: ever hear a sound like this? [Re: emarine01] #1186569
02/26/12 08:51 PM
02/26/12 08:51 PM
Marysville, O-H-I-O
Marysville, O-H-I-O
Not when you use a valve cover cut up to keep the mess down!
