Standard Dash Modification #1186281
02/26/12 11:32 AM
02/26/12 11:32 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Im sure this question has been asked before somewhere but I want to add an a true oil pressure guage in the blank spot on my standard dash cluster. Has someone done this? where can you get a guage for it. Anyone aftermarket these?
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Standard Dash Modification [Re: 19cuda73] #1186282
02/26/12 11:53 AM
02/26/12 11:53 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Goody did this years ago.
http://www.cuda-challenger.com/cc/index.php?topic=67749.0
Re: Standard Dash Modification [Re: moparpollack] #1186283
02/27/12 10:56 PM
02/27/12 10:56 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Standard Dash Modification [Re: 19cuda73] #1186284
02/27/12 11:11 PM
02/27/12 11:11 PM
NC
1970A66 Offline
1970A66  Offline
NC
oh man, thats the ticket! ^^
Re: Standard Dash Modification [Re: 1970A66] #1186285
02/28/12 09:00 AM
02/28/12 09:00 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
That red line gauge is sweet, but it sure is expensive. I put an oil pressure gauge in that spot on my Cuda years ago - it was a hand-me-down from one of my friends, and it just happened to fit perfectly in the hole. It's been there ever since.
The one problem you're going to run into is that the dash lights don't shine in that area, so it's very hard to read the gauge at night. Switching to a 4-light rally gauge light bar didn't help much, but I stumbled across a solution a few years ago. I found that they make blue light bulbs that fit into the side marker light holders for the 72 - 80's Mopars. I shaved down one of the rubber side marker light sockets to reduce it's size (you can find new sockets at most auto parts stores), and mounted it at the edge of the light bar, just above my oil pressure gauge with a small sheetmetal strap. It's up and out of the way, you can't see it unless you stick your head down by the floor and look up, and it adds a ton of light over on the far side of the instrument panel. That blue bulb is a close match to the existing light from the light bar, and I found those at Wal-Mart. After seeing how much easier it was to see the gauges with the extra light, I mounted a second bulb on the other end of the light bar. After struggling for years with the poor lighting for the gauges, it's a nice change to be able to see them clearly at night.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
