BB intake sealing? Use metal valley pan gasket only?
#118615
09/10/08 11:20 AM
09/10/08 11:20 AM
Posts: 561 Oakland, CA
68Bullet
Oakland, CA
So I am fighting the issues I've had since I first started driving BB cars, intake leaks. Right now oil is getting sucked into the intake and smoking out the back - bad news. I am running the steel valley gasket straight to the heads, with a fel pro gasket between that and my alumnium intake manifold.
I am thinking, the factory ONLY used the valley pan gasket, nd I've never tried it that way. Should I? And if so, should I use any RTV?
I figure if everything else I've tried hasn't worked, might as well do what the factory found tried and true
"Broke is temporary, cheap lasts forever"
Re: BB intake sealing? Use metal valley pan gasket only?
[Re: 68Bullet]
#118617
09/10/08 11:30 AM
09/10/08 11:30 AM
RapidRobert
many different opinions on this. The paper gaskets are too thick & they aren't cut perfect enough to suit me. My preference is to use very light amt of #2 permatex in the tube on both side of the valley pan. No problems yet. RTV would work the same but get the right kind of RTV that is gasoline resistant.
[Re: 68Bullet]
#118618
09/10/08 11:37 AM
09/10/08 11:37 AM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
i spray copper head gasket spray on both sides just around ports, have reused valley pan 4 times like this with no leaks on race car. also used disc brake pad spray also that red liquid rubber. if still wont seal check intake for warpage
MOPAR OR NO CAR
[Re: DaytonaTurbo]
#118622
09/10/08 02:51 PM
09/10/08 02:51 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Ive installed them dry for over 40 years.I just use a little RTV in the 4 corners where they meet the head and a slight bit under the hold downs are.Never use RTV on the intake ports its trouble waiting to happen.Rocky
Chrysler Firepower
[Re: 68Bullet]
#118623
09/10/08 03:45 PM
09/10/08 03:45 PM
Posts: 120 Arizona
anmracing
Arizona
If you use RTV, use very little. Just enough to seal any imperfections. We've always done it without but have known others who have used it without any problems.... EDIT: I need to learn how to spell.....
