Power steering leak #1186028
02/25/12 06:46 PM
02/25/12 06:46 PM
Tucson, AZ
moparjimm Offline OP
Tucson, AZ
Here's another one for those out there. On my 66 Charger, the power steering leaks, but ONLY when I go backwards. Could this be the seal above the pitman arm, as this seems to be the only thing that changes??? I have already replced bothe hoses, needed to anyway, the back of the pump is dry.
Re: Power steering leak [Re: moparjimm] #1186029
02/25/12 07:15 PM
02/25/12 07:15 PM
Kirkland, Washington
Pacnorthcuda Offline
You need to inspect the system with the engine running, while a helper turns the wheel from lock-to-lock. You'll find the leak
Re: Power steering leak [Re: Pacnorthcuda] #1186030
02/25/12 10:06 PM
02/25/12 10:06 PM
Eastern,NC
68GTS383 Offline
68GTS383  Offline
Eastern,NC
TransX works good on P/S leaks!
Re: Power steering leak [Re: Pacnorthcuda] #1186031
02/26/12 08:12 PM
02/26/12 08:12 PM
Tucson, AZ
Tucson, AZ
It only does in reverse, so your idea is very dangereuos to life and limb.
