Challenger brake pedal/pad? 4sp/auto brake pad change #1185806
02/25/12 01:29 PM
02/25/12 01:29 PM
Fairfield, Ohio
holtzdog55 Offline OP
Fairfield, Ohio
Challenger, with 4sp pedals, linkage still in car with clutch pedal linkage removed.....since the brake pad is smaller on 4sp can I take an Automatic brake pad and put it on the same linkage as the 4sp brake pad?? don't have access to look at it right now but would like to know if this is possible or would all the linkage have to be changed??? works fine as an auto as is but would like a bigger brake pad if it's easy to do .....thanks.
Finally Done....BEERS!!!
Re: Challenger brake pedal/pad? 4sp/auto brake pad change [Re: holtzdog55] #1185807
02/25/12 04:57 PM
02/25/12 04:57 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
So you have an auto in there now? Not 100% sure of the question, but I don't think the pads will interchange. Auto is much larger. I have the complete linkage from a B body swap I did (auto to 4 speed) that still has the auto pedal attached. You can have it if you want. I'll be at the Mopar Swap Meet next Sat. Let me know, and I'll bring it along. Take care, Jeff
Re: Challenger brake pedal/pad? 4sp/auto brake pad change [Re: 1969RR] #1185808
02/25/12 06:05 PM
02/25/12 06:05 PM
Fairfield, Ohio
Fairfield, Ohio
thanks for the info ....where is the swap meet next week? I'm in Cincinnati area......
Re: Challenger brake pedal/pad? 4sp/auto brake pad change [Re: holtzdog55] #1185809
02/26/12 09:06 PM
02/26/12 09:06 PM
Fairfield, Ohio
Fairfield, Ohio
anybody else????
Re: Challenger brake pedal/pad? 4sp/auto brake pad change [Re: holtzdog55] #1185810
02/26/12 11:12 PM
02/26/12 11:12 PM
Connecticut
biginchmotor Offline
Connecticut
I have a couple of extra E body automatic brake pedals, let me know and I will send you one. I can send you some pictures if you like, John.
Re: Challenger brake pedal/pad? 4sp/auto brake pad change [Re: biginchmotor] #1185811
02/27/12 12:24 AM
02/27/12 12:24 AM
Fairfield, Ohio
Fairfield, Ohio
Sounds good ....pics would be good too....
aholtzapple@cinci.rr.com
We can go from there......Thanks, Tony
