PCV valve education
#1185741
02/25/12 12:24 PM
02/25/12 12:24 PM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
Ok I know the gist of the PCV valve operation (or I thought I did) couple of questions...
With all the talk of PCV on 4.7 engines and with my Durango and using some oil mysteriously lately (which is not showing up on the plugs) I thought it was time to clear the water on a few questions.
1. Should a PCV valve have full vacuum present on the motor side of the valve at IDLE, or should it be sucked closed?
2. What are the symptoms of a stuck open PCV?
3. Does anyone know if the PCV on a 02 Durango is spring loaded or is it just a "rattle" valve?
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: PCV valve education
[Re: kilroy]
#1185743
02/26/12 12:16 AM
02/26/12 12:16 AM
Posts: 4,946 WI
Dcuda69
WI
[Re: Dcuda69]
#1185745
02/26/12 12:26 AM
02/26/12 12:26 AM
kilroy
Iowa State fan
Ive got full vacuum at idle in my durango. When I put my finger over it I can hear the valve snap inside, but It has FULL vacuum at idle and I couldn't get a straight answer googling things. Would this cause some oil consumption.
[Re: kilroy]
#1185746
02/26/12 12:35 AM
02/26/12 12:35 AM
Posts: 4,946 WI
Dcuda69
WI
That sounds pretty normal....if in doubt just replace the valve(with the correct, quality part)Don't forget to check the fresh air side of the pcv system.
[Re: kilroy]
#1185749
02/26/12 03:28 PM
02/26/12 03:28 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
It was interesting that on the cast iron 8l v10 Chrysler went with a fixed orifice instead of a rattle type PCV Here s another variation http://www.envalve.com/why.htmlIn theory Having a low vacuum inside the block During part throttle cruise Would give a slight fuel economy benefit ... The backside of the piston would not be fighting against a pressure and internal moving parts would encounter "wind age" aerodynamic losses
[Re: kilroy]
#1185750
02/27/12 09:59 AM
02/27/12 09:59 AM
Posts: 541 chatham, Ilinois
fox
super street
super street
chatham, Ilinois
A stuck or imoperative PCV valve can cause a motor to gum up and then use oil. But, I've never seen one working cause it. The PCV valve really never completely closes, tha tI've seen. They open fully at low vacuum/WOT.
