AndyF waterpump block spacers #1185704
02/25/12 10:34 AM
02/25/12 10:34 AM
Salina ks
572_dup2 Offline OP
Back On The Bumper!!
572_dup2  Offline OP
Salina ks
Got a belt drive distributor an went to remote pump. Had Andy make me some of his waterpump blocks. Wow these are some series nice pieces!!
Shawn Jennings
Re: AndyF waterpump block spacers [Re: 572_dup2] #1185705
02/25/12 02:14 PM
02/25/12 02:14 PM
AndyF Offline
AndyF  Offline
Thanks for the order. Are you going with AN fittings for the water lines?
Re: AndyF waterpump block spacers [Re: AndyF] #1185706
02/25/12 02:16 PM
02/25/12 02:16 PM
AndyF Offline
AndyF  Offline
You can also get hose fittings. I use 1" heater hose on the dyno. It is a lot less expensive than AN and it is super easy to work with. Just cut it to length and install with a hose clamp.
Re: AndyF waterpump block spacers [Re: AndyF] #1185707
02/25/12 08:52 PM
02/25/12 08:52 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
Top pic. Already have all my stuff. Put motor in today will be running soon.
Shawn Jennings
Re: AndyF waterpump block spacers [Re: 572_dup2] #1185708
02/25/12 11:26 PM
02/25/12 11:26 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
so what remote pump?
Re: AndyF waterpump block spacers [Re: 572_dup2] #1185709
02/26/12 02:04 AM
02/26/12 02:04 AM
AndyF Offline
AndyF  Offline
Are you going to hook it up with normal water flow, or plumb it for reverse flow?
I ran reverse flow on the dyno for a couple of years and then switched back to normal flow. I never really saw any difference but I think that normal flow is safer.
Re: AndyF waterpump block spacers [Re: AndyF] #1185710
02/26/12 11:39 AM
02/26/12 11:39 AM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
16 volt
Shawn Jennings
