70 Cuda Vinyl top #1185629
02/24/12 09:50 PM
02/24/12 09:50 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
Anyone have an unmolested original vinyl top 70 Cuda? The painter destroyed the top on my car. When I called Legendary to inquire about the one they repop the width of the seams is wrong. My top measures 30" outside to outside of tne seam. So I am asking anyone with an original top to please measure the seams on their car and let me know what they are. Could there be a factory variance?
Real Men shift for themselves
Re: 70 Cuda Vinyl top [Re: 1DGEMAN] #1185630
02/25/12 08:16 PM
02/25/12 08:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I have 2 Legendary tops on my Cudas, the seams measure 31 1/2 " outside to outside, not sure of "original" dems. if they are that important to you, KEE Auto Top.com makes tops to order/specifications supplied by the customer....are you 100% sure the top is factory?
Re: 70 Cuda Vinyl top [Re: DAYCLONA] #1185631
02/27/12 04:39 PM
02/27/12 04:39 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
Yes it is the original top. Original owner of car.
Re: 70 Cuda Vinyl top [Re: 1DGEMAN] #1185632
02/27/12 11:14 PM
02/27/12 11:14 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Is it a Gator grain top? Someone, somewhere long ago mentioned they were 30".
It would be good to know for sure.
Re: 70 Cuda Vinyl top [Re: Alaskan_TA] #1185633
02/28/12 03:21 AM
02/28/12 03:21 AM
USA
big-block-dave Offline
USA
I'll get back to ya on that! Did you measure at front AND rear window?
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
Re: 70 Cuda Vinyl top [Re: big-block-dave] #1185634
02/28/12 12:36 PM
02/28/12 12:36 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
Yes measured front and back and under rear window. It is a very early production car.
Re: 70 Cuda Vinyl top [Re: big-block-dave] #1185635
03/02/12 03:52 PM
03/02/12 03:52 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
So Big Block Dave did you get a chance to measure?
Re: 70 Cuda Vinyl top [Re: 1DGEMAN] #1185636
03/03/12 07:42 PM
03/03/12 07:42 PM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
Barracuda original top reference
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: 70 Cuda Vinyl top [Re: MMC Detroit] #1185637
03/03/12 07:56 PM
03/03/12 07:56 PM
Kirkland, Washington
Pacnorthcuda Offline
Thats from the far side of the seam to the far side of the other right?
Re: 70 Cuda Vinyl top [Re: Pacnorthcuda] #1185638
03/03/12 08:00 PM
03/03/12 08:00 PM
I just measured my legendary top on the 70 'Cuda and its 31.75" from seam to seam, so there definately is some variance to these.
Re: 70 Cuda Vinyl top [Re: Pacnorthcuda] #1185639
03/03/12 08:09 PM
03/03/12 08:09 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
But the big question is, does it really matter?, and if so?, why?
Re: 70 Cuda Vinyl top [Re: DAYCLONA] #1185640
03/03/12 08:14 PM
03/03/12 08:14 PM
It doesn't to me, and likely not to you, but these are Mopars, so you KNOW it means the world to some!
I am glad I am not saddled with the burdon of must be stock/100% factory correct.
Re: 70 Cuda Vinyl top [Re: Pacnorthcuda] #1185641
03/03/12 08:19 PM
03/03/12 08:19 PM
Texas
Ron69rr Offline
Ron69rr  Offline
Texas
AMEN BROTHER. These cars are getting older and older and if you paint them nice and throw them together your doing better than the factory did.
Re: 70 Cuda Vinyl top [Re: Ron69rr] #1185642
03/03/12 09:19 PM
03/03/12 09:19 PM
USA
USA
1DGEMAN, i got your PM but for some reason the site won't let me reply? Never had that problem.........Anyways i did measure. At the top of the front and rear window it is 30 1/4". At the bottom of the rear window and at the chrome molding it measures 31" STRAIGHT ACROSS, NOT bending on the arc of the window.
I would think that Legendary could easily make you a top with the 30 1/4" seam on top and the 31" bottom of window?
Some companies will change their product if you prove correctness, but where did they get the measurements they have now?
Several years ago i straightened out Phoenix Graphics on the '69 'cuda decal they were producing. Their's was terribly off from original!......today they are correct.
