Trunk pannel question #118529
09/10/08 02:29 AM
09/10/08 02:29 AM
Montana
N
NateJM Offline OP
NateJM  Offline OP
N
Montana
Hi guys I have a 1968 charger I have to put new floor boards in the trunk. I see on ebay there is a guy that sells them in a one peace or two peace. wich is the best way to go?
Thanks Nathan
Re: Trunk pannel question [Re: NateJM] #118530
09/10/08 05:41 AM
09/10/08 05:41 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
depends on how much other body work you need to do.
the 1 piece won't fit, unless you remove the tail panel or quarter panels as well.
so if all you're doing is the trunk floor you need to get the 2 piece ones, so that they will fit through the trunk opening.
...at least, that's how it is with the E body's.
**Photobucket sucks**
