Spark Plugs and Anti-Seize - What kind to use?
#1184947
02/23/12 04:26 PM
02/23/12 04:26 PM
Posts: 1,075 United States
STLDuster
United States
What kind of Anti-seize do you guys use when installing new spark plugs in aluminum heads? Would you want to use a copper based, nickel based, etc? Would it even make a difference?
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Spark Plugs and Anti-Seize - What kind to use?
[Re: STLDuster]
#1184950
02/23/12 06:11 PM
02/23/12 06:11 PM
Posts: 1,605 westerly, ri. usa
440lebaron
westerly, ri. usa
hello, i was told not to use it by sparkplug companys, because it stop heats transfer and not to remove them when engine is hot.....anyway gary seeya
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 1962Savoy]
#1184955
02/24/12 08:35 AM
02/24/12 08:35 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Ive used the silver since the 70s.Never any problems and Ive probally replaced thousands of plugs at work and home.Try and get a set of 100K plugs out of a late Ford truck V8 and see why you will use it.Most use too much.Just need a tiny bit on the threads.Rocky
Chrysler Firepower
[Re: jamesc]
#1184960
02/24/12 01:50 PM
02/24/12 01:50 PM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
on th funny car we used red n tacky from lucas.
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
[Re: kissmyaspen]
#1184961
02/24/12 02:25 PM
02/24/12 02:25 PM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
I don't use it anymore either. I take my plugs out all the time (aluminum heads) and have never had a problem.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
[Re: Moparnut426]
#1184962
02/24/12 02:38 PM
02/24/12 02:38 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
I have never used it on plugs, like said a drop of oil works just fine. I also dont use it on wheel lug nut. Ive seen way too many wheels from Wal Mart fall off.
College instructor told me never use it on plugs. Dothe the heat transfer issue, and getting it on the plug itself are the reasons I dont. Never had any issues with them.
Kasey
Odd, I've used anti-seize on my truck wheels for 30 years and never had a wheel fall off. Try that on a semi and not use it and try to get the inside lugs off. You will wish you had used it. I guess it is all about how you tighten things up.
[Re: Dodgeguy101]
#1184963
02/24/12 03:12 PM
02/24/12 03:12 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Kasey
Semi wheels are flat wahser lug style, the acorn style that are taper seat you are not supposed to use anti-sieze cause it can cause the lug the back off from vibration when it gets on the taper mating suface. I put a little drop of oil on the wheel stud threads when I put lug nuts back on. Some ford trucks are flat washer style and you can use anti-sieze on them if you wish.
as for spark plugs I was also told not to use anti-sieze as it adds resistance to the plug so I just put a small drop off oil on the threads.
DEPUTY Odd, I've used anti-seize on my truck wheels for 30 years and never had a wheel fall off. Try that on a semi and not use it and try to get the inside lugs off. You will wish you had used it. I guess it is all about how you tighten things up.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: slammedR/T]
#1184964
02/24/12 03:22 PM
02/24/12 03:22 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Kasey
Alrighty then.
[Re: Dodgeguy101]
#1184966
02/24/12 03:35 PM
02/24/12 03:35 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
Kasey
I like it on a semi wheel, but I use it on the inside square headed stud, and not the nut. Dad-in-law has a Freighshaker, and we both do the same on the inner stud. Here in Nebraska they use a crap load of salt on the raods, and ive never been able to NOT get the nuts loose.
