High speed miss #118492
09/09/08 11:38 PM
09/09/08 11:38 PM
Hillsdale,Mi
69swinger340 Offline OP
Hillsdale,Mi
I have developed a miss at high rpm's, starts popping through the exhaust at 4200-4500. Heres the combo 360, eddy heads, 650 holley double pumper, pertronix ignition, MP .528 solid lift cam. Motor is fresh about 250 miles on it. I thought I had a couple fouled plugs, replaced plugs, no change. Checked valve lash, all were still right on .017. Thought it may have been lack of fuel, swaped fuel pumps and tore carb down and cleaned all the passages out. Still no change. Any suggestions???
*69 swinger 340 4spd *70 T/A 340+6pk 4spd
Re: High speed miss [Re: 69swinger340] #118493
09/09/08 11:44 PM
09/09/08 11:44 PM
plug wire went bad
Re: High speed miss [Re: RapidRobert] #118494
09/09/08 11:52 PM
09/09/08 11:52 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Check the wires, particularly near the spark plug ends. Carefully try to pull off the 180 degree boots. Or, at least inspect each and every one. New plug wires are cheap insurance, anyway.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
