904 kickdown lever question #1184858
02/23/12 03:19 PM
02/23/12 03:19 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I'm currently rebuilding my 904 with donor parts from another one with the low gear set. I noticed that my original kick down lever is a 3.2 and the donor has a 3.8. Any advantage to changing?
Re: 904 kickdown lever question [Re: JonC] #1184859
02/23/12 03:55 PM
02/23/12 03:55 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The 3.8 will apply more leverage to hold the band , the down side is it releases a hair slower . Swap it in.
Re: 904 kickdown lever question [Re: JohnRR] #1184860
02/23/12 09:16 PM
02/23/12 09:16 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I think I understand that part, but what would I expect to feel, experience or expect the transmission to do.?
Re: 904 kickdown lever question [Re: JohnRR] #1184861
02/23/12 10:40 PM
02/23/12 10:40 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
WRONG only the 5.0 had a tendency to hang up and only if it was out of adjustment (too loose)
The 4.2 is considered the best overall and the 3.8 works great putting more leverage into stopping the drum to get it to shift into second!
Re: 904 kickdown lever question [Re: Dodgem] #1184862
02/23/12 10:54 PM
02/23/12 10:54 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Does that translate into a harder or quicker shift and if so is it harder on other components of the transmission?
Re: 904 kickdown lever question [Re: Dodgem] #1184863
02/24/12 04:25 PM
02/24/12 04:25 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
If you think about it that doesn't make sense; the looser the band, the less likely it will drag on release.
Even a properly adjusted 5.0 lever will drag more on release than a lower ratio adjusted to the same servo plunger travel.
