Seat Heater on 2001 300M: #1184648
02/23/12 08:59 AM
02/23/12 08:59 AM
Highland, MI.
Sunroofcuda Offline OP
Highland, MI.
Up until now, both seat heaters have worked perfectly on my wife's 2001 300M. now, the RH seat heater does not work - the light will not come on either lo or hi setting. Driver's seat still works fine. Where should I look first? Separate fuses, or maybe the switch is bad?? I haven't even looked into it yet. Let's assume the wire is still hooked up fine.
Thanks.
Re: Seat Heater on 2001 300M: [Re: Sunroofcuda] #1184649
02/23/12 11:23 AM
02/23/12 11:23 AM
ogletownpa
3
383'D Offline
383'D  Offline
ogletownpa
I believe they have a problem with the switch going bad. I think it pops out and you can get them at advance auto. I had the same problem and researched it a little but ended up getting rid of the car before fixing it
Re: Seat Heater on 2001 300M: [Re: 383'D] #1184650
02/23/12 01:36 PM
02/23/12 01:36 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Check TSB's first. I have had grid , moldule and switch problems with them before. I cant remember if there was a TSB on any of it so I would check. Ron
