Main bearing questions. Please Help!! #1184643
02/23/12 07:43 AM
02/23/12 07:43 AM
Ohio
fiddlestix Offline OP
Ohio
I have a 1975 440 block I am building a 493". This block has the larger thrust diameter on the #3 saddle. I was going to use some FM 119M bearings I have with the smaller thrust diameter. My question Is this a problem or common practice? I have also drilled the #2,3,4,5 mains to 9/32" diameter for oiling and I noticed the bearing oil holes are only .250". Do you guys drill out the main bearings to match the enlarged holes in the block?
Thanks you for any help you can give me.
Re: Main bearing questions. Please Help!! [Re: fiddlestix] #1184644
02/23/12 01:18 PM
02/23/12 01:18 PM
dogdays Offline
dogdays  Offline
The smaller thrust will work, but not last as long as the larger one. That's probably not a concern for you, though.
R.
Re: Main bearing questions. Please Help!! [Re: dogdays] #1184645
02/23/12 08:42 PM
02/23/12 08:42 PM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
Yes on drilling the bearing hole, otherwize the block drill was for not.
Re: Main bearing questions. Please Help!! [Re: Cuda367] #1184646
02/23/12 08:57 PM
02/23/12 08:57 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Re: Main bearing questions. Please Help!! [Re: Biginchmopar] #1184647
02/23/12 10:49 PM
02/23/12 10:49 PM
Ohio
Ohio
Thanks guys!!!
