Re: balencer question 5.9 magnum 360
[Re: Rick_Ehrenberg]
#1184480
02/23/12 02:10 AM
02/23/12 02:10 AM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
If it is truly a Magnum, you need a Magnum damper (and f'wheel, flex plate, or converter).
There were 2 styles of Mag 360 dampers: With and w/o integral pulleys.
Rick
Couldn't have been answered better
[Re: BulletBob]
#1184481
02/23/12 03:49 AM
02/23/12 03:49 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
96 up 5.9L Magnum's used a weighted flex plate.No weights on the converter.I think the changes came in with OBD II and the J-Tech engine controller.
Leave the gun.......take the Cannoli's....Mike
[Re: F. Sadler]
#1184482
02/23/12 07:55 AM
02/23/12 07:55 AM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Currently going through the same thing. I put an 03 flex plate and 99 balancer on a 94 block and crank. Hope to start it up in the next couple of weeks.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: F. Sadler]
#1184484
02/24/12 01:44 AM
02/24/12 01:44 AM
dfsmopars
Kentucky
I have the v belt system off my 72 318 on my Magnum. Everything looks like it is going to work well. Hope to fire it up in two weeks.
