1972 400 Oil Dipstick Tube #1184054
02/22/12 02:54 PM
02/22/12 02:54 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Online content OP
moparmike1  Online Content OP
Hi Everyone,
I have a 1972 Road Runner with a 400 that needs the dipstick tube replaced. The original had two bends in it with a tab that is bolted to the engine mount. The replacement has one bend it with a tab that is bolted to the engine mount. Here's a link to Rick Ehrenberg's auction showing a picture of the replacement.
Ehrenberg's Auction
The engine is in the car and I tried installing the replacement but ended up damaging it so now I have another one on the way. I'll be filing down the part of the tube that fits into the block but I think the bolt that comes from the engine mount will still be a problem since it's in the direct path of the tube. This bolt is pressed into the mount, it can't be removed and put back when the tube is installed.
Does anyone have any suggestions on how they handled this?
Thanks,
Mike.
Re: 1972 400 Oil Dipstick Tube [Re: moparmike1] #1184055
02/22/12 03:24 PM
02/22/12 03:24 PM
Shoreline, Washington
72roadrunnergtx Offline
Pretty common to have to file or cut down the portion of the aftermarket tube that fits in to the block for the correct fit. The bolt is not pressed into the motor mount bracket, may need to loosen the other bolts to get the bolt, that secures the tube, out in order to fit the tube.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: 1972 400 Oil Dipstick Tube [Re: 72roadrunnergtx] #1184056
02/22/12 04:00 PM
02/22/12 04:00 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I made this out of 3/8" pipe. Goes over the D/S tube to drive it into the block.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 1972 400 Oil Dipstick Tube [Re: 72roadrunnergtx] #1184057
02/22/12 05:21 PM
02/22/12 05:21 PM
Hi Doug,
Thanks for the pictures. The bolt I'm referring to is the top one in the motor mount that your dipstick tube's bracket is attached to. I thought it was pressed in but will look again tonight.
Thanks for the tip Mark about the 3/8 pipe piece. I may have to make something similar.
Mike.
Re: 1972 400 Oil Dipstick Tube [Re: moparmike1] #1184058
02/22/12 08:03 PM
02/22/12 08:03 PM
IN
ahy Offline
ahy  Offline
IN
Agree the motor mount bolt will come out... mine does. Also, its common to need to sand down the part that goes in the block. For pressing it in the pipe tool looks good. A 3/8" crows foot wrench on a long socket extension works well also.
On mine, I had to "adjust" the mounting tab for the motor mount bolt but it all went together.
Re: 1972 400 Oil Dipstick Tube [Re: moparmike1] #1184059
02/23/12 11:02 AM
02/23/12 11:02 AM
IMGTX Offline
IMGTX  Offline
Make sure the old one came out in one piece.
Very common for the tip to break off in the block.
Re: 1972 400 Oil Dipstick Tube [Re: IMGTX] #1184060
02/23/12 03:22 PM
02/23/12 03:22 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I hope someday we will get correct tubes for 73 and lates.
these needs to be reshaped due the diff engine mount
BTDT twice!
