2001 Durango 4.7 trans issue when cold #1183915
02/22/12 11:10 AM
02/22/12 11:10 AM
Carson City, NV
babarracuda Offline OP
Carson City, NV
MY Durango does not want to shift back to first gear when cold. It will load then engine and then it stalls. Only one time. Any ideas?
Re: 2001 Durango 4.7 trans issue when cold [Re: babarracuda] #1183916
02/22/12 06:36 PM
02/22/12 06:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Sounds more like the converter isn't unlocking when you come to a stop.
Get a code reader and check for codes.
Re: 2001 Durango 4.7 trans issue when cold [Re: John_Kunkel] #1183917
02/22/12 08:09 PM
02/22/12 08:09 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Check the trans fluid level when hot in nuetral. Its very important that the level is correct or the converter can stay locked up. That trans (45rfe or 545rfe)actually uses the fluid pressure unlock the converter clutch and we had some that when the fluid was low it had the converter clutch lock up at idle. Ron
