Re: wheel backspacing
[Re: 8urvette]
#1183841
02/22/12 11:15 AM
02/22/12 11:15 AM
Posts: 52,972 Romeo MI
MR_P_BODY
how about wheel spacers??? can you run them safely? maybe its time to 4 link it....
I would find a set of wheels I like with about a 4 1/2" back spacing(which most of the wheels would have) and cut the diff and axles BUT if you wanted to go to a 4 link thats always good........JMO
[Re: 8urvette]
#1183844
02/22/12 01:22 PM
02/22/12 01:22 PM
Posts: 16,545 On the run…
BloFish
On the run…
I prefer my backspace centered on the wheel, just my : But I do have a 4 link set up, so I was able to do it my way versus having to settle.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: 8urvette]
#1183845
02/22/12 01:28 PM
02/22/12 01:28 PM
MR_P_BODY
i wondered if it would be hard on the bearings, but talking it through with a friend, why does it matter to the bearing where the backspacing is on the wheel? a low back spacing with a wide wheel would be the same on a bearing as a taller wheel with more backspacing right? similar pressures on the bearing, right?
Its a leverage thing... the farther you move away from the bearing the greater the leverage
[Re: 8urvette]
#1183847
02/22/12 01:35 PM
02/22/12 01:35 PM
MR_P_BODY
thats what i was trying to say, but dana 60's run 44 inch tall tires.... that weigh a lot!!!! they seem to last... is a 15 inch wheel really going to cause that much of an issue?
Maybe not BUT it will still add load to the bearing
[Re: 8urvette]
#1183849
02/22/12 02:02 PM
02/22/12 02:02 PM
Posts: 3,210 robin hood country
deaks
robin hood country
There was a thread a while ago, re inboarding springs and one guy posted some pics of his springs on the inside of the frame rails front and back, i cant remember his name though. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
