2008 Avenger 2.4 engine code #1183634
02/21/12 07:44 PM
02/21/12 07:44 PM
places
79powerwagon Offline OP
places
Was this just a "perfect storm" of events to cause this, or???
It was snowing like mad this morning while driving to work, that heavy, wet snow. I ended up behind a county snow plow and was pelted with slush, snow, water, and salt. At this very time, we both started down a long. dangerous hill with a curve mid-way, and a stop at the bottom. It was VERY icy! Cars trying to come up weren't making it.
Since I was behind the snow plow and heading down hill at a slow pace, I decided to put my automatic into 3rd to engine brake some, and was ready to shift lower if needed.
Within seconds, a chime started ringing and a light started flashing on the dash. Noting I could do about it there, so I kept going. I got to the stop sign, the plow got out of the way, and I continued to work (I had less than 3 miles to go). The car was barely running and obviously in a limp mode. I hobbled to work, pulled out the owner's manual and went to my office to find out which light was lit.
It was the throttle position sensor warning light, and no other CEL were illuminated.
At lunch time, I went out to try and start it, it started just fine, no lights, no chimes, no issues. I turned it off and went back to work. No issues on the way home (no precipitation).
This a 2008 with 54000 miles on it. Could the combination of wet, down-shifting, etc. cause something like this? Other than getting hooked to a scan tool, is there anything to look for?
I've had this car since mid December, no issue like this before, rain, snow, or shine.
Thanks in advance!
Re: 2008 Avenger 2.4 engine code [Re: 79powerwagon] #1183635
02/21/12 08:52 PM
02/21/12 08:52 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You need to find out the actual DTC set to properly diagnois the issue. FWIW, they are known for throttle body issues and it may be your problem. It may have just froze up causing the butterfly to stick. Since they are drive-by-wire they are more trouble prone than a standard cable operated unit.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2008 Avenger 2.4 engine code [Re: 71yelladustr] #1183636
02/21/12 10:01 PM
02/21/12 10:01 PM
places
places
Known for TB issues? I didn't find anything in a quick search. No matter! I'll stop at the shop and get it scanned.
Thank you for the input! It's most appreciated!
Re: 2008 Avenger 2.4 engine code [Re: 79powerwagon] #1183637
02/21/12 10:38 PM
02/21/12 10:38 PM
kalispell montana
jwilson 61 Offline
jwilson 61  Offline
kalispell montana
turn key on off on off on and wait for codes to come up on your odometer no sense paying someone for what you can do
70 cuda 440 6bbl Auto with a dana 60
68 road runner QQ1 383 auto
1970 6 barrel 4 speed Superbird FY1 number matching
15 Challenger 6.4 SRT pearl White 6 Speed
72 Cuda 440 5 speed
71 Road Runner 440 4 speed
Re: 2008 Avenger 2.4 engine code [Re: jwilson 61] #1183638
02/21/12 10:45 PM
02/21/12 10:45 PM
places
places
I will try that!
