67 318 exhaust manifold gaskets #1183591
02/21/12 05:59 PM
02/21/12 05:59 PM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
today i began stripping down my old virgin motor to swap over to a donor 318 untill i can afford to have my orignal rebuilt when i poped off the factory exaust manifolds i noticed there were no gaskets!!! when the engine ran it had no exhaust leaks is this how they were back then? it blew my mind lol should i use exhaust gaskets with these manifolds when i bolt them to an 87 set of heads? i have never seen gaskets not used on manifolds but if its not broke i wont fix it any one ever seen such a thing
67 charger fastback 318 stock 67 belvedere II 4dr soft top built 318 68 newport 2dr hard top 318 84 b150 440/727 84 d150 short wheel step side 4x4 lifted 87 omnitruck (you just have to see it ) new addition 63 dart wagon !!!
Re: 67 318 exhaust manifold gaskets [Re: gogo318] #1183592
02/21/12 06:05 PM
02/21/12 06:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No gaskets from the factory because you were dealing with bacisally virgin machined surfaces . 40 plus years later, use them if you got them.
Re: 67 318 exhaust manifold gaskets [Re: JohnRR] #1183593
02/21/12 08:41 PM
02/21/12 08:41 PM
& if you dont just use a thin coat of the RTV made for high heat, copper?
Re: 67 318 exhaust manifold gaskets [Re: gogo318] #1183594
02/23/12 04:08 PM
02/23/12 04:08 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
you dont need them... i have never used these gaskets even after a rebuild, and i never had any leakes either.. as long as its all flat your good..
