Page 3 of 3 1 2 3
Re: well im now in the tunnel ram club- i have a question [Re: shoebox] #1183427
02/23/12 12:43 PM
02/23/12 12:43 PM
gregsdart Offline
gregsdart  Offline
the 1987 intake has a small port in it for some BB applications. I picked up a solid .15 by porting mine on a stroker that had ported 906 heads.
Re: well im now in the tunnel ram club- i have a question [Re: gregsdart] #1183428
02/23/12 01:21 PM
02/23/12 01:21 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
thats one of the reasons im going to run it. it doesnt look "too big"
i think its going to kick butt on my milder combo!
74 dart sport 440 www.Csucarbs.com
Re: well im now in the tunnel ram club- i have a question [Re: shoebox] #1183429
02/23/12 01:45 PM
02/23/12 01:45 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
Uploaded with ImageShack.us
Re: well im now in the tunnel ram club- i have a question [Re: Lil Demon] #1183430
02/23/12 02:03 PM
02/23/12 02:03 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Well, I have a question about tunnel rams. I remember reading a while back, going to show my age, but the article was about taking a tunnel ram for a B block and making spacers out of pylwood so it could be used on a RB block. Could you do that and open the ports up to M/W size? If you did that would the runners in the manifold be large enough to support the M/W ports in EZ-1 heads? I know it would work, but would it work as well as the Indy tunnel ram? If not what could you expect to loose with this set up? I know it is only a guess, but just wondering.
Re: well im now in the tunnel ram club- i have a question [Re: Ari440] #1183431
02/23/12 02:08 PM
02/23/12 02:08 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
I ran a pair of 750's, converted them to 4-corner idle circuits, and Dominator style secondary throttle blade adjusters. Used the Enderly linkage.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: well im now in the tunnel ram club- i have a question [Re: Dodgeguy101] #1183432
02/23/12 02:10 PM
02/23/12 02:10 PM
St. Charles, MO.
St. Charles, MO.
Dodgeguy, just have aluminum welded on the tops of the runners and port to Max-Wedge size, guys have been doing that for ages.
Re: well im now in the tunnel ram club- i have a question [Re: Slingshot383] #1183433
02/23/12 02:13 PM
02/23/12 02:13 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Thought I could be cheap and get a B manifold, but you are right, that is a better option.
Re: well im now in the tunnel ram club- i have a question [Re: Dodgeguy101] #1183434
02/25/12 02:37 AM
02/25/12 02:37 AM
Pa
W
W7_Scamp Offline
W7_Scamp  Offline
W
Pa
Shoebox I helped build almost that exact combo 440 .030 2295f stock crank and rods w arp rod bolts. 590-312 mp cam home ported edelbrocks M1 tunnelram w 2 660's 727 w J converter 4:30 gears in street valiant ran 10.30's at 130 trust me nothing fancy but took a beating. the owner is a member here maybe he'll chime in
Re: well im now in the tunnel ram club- i have a question [Re: W7_Scamp] #1183435
02/25/12 02:14 PM
02/25/12 02:14 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Awesome! I always wanted the 590 but I need to keep the rpm's in
Check. This 256 108 cam should drive a lil better I'd be thrilled
With a 10.xx @123 with my car!
Re: well im now in the tunnel ram club- i have a question [Re: shoebox] #1183436
02/25/12 11:38 PM
02/25/12 11:38 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
Its a simple combo that is very effective, but I still think it requires a little rpm to get it to work good. TR's by nature tend to like a little rpm. The car responded well when I moved the shifts points to 6600.
The 4200 converter hurt my car more than anything as it was always a struggle to get the car to 60ft in the low 1.50's. When I called PTC, he suggested something in the mid to high 5000 range to make the combo work better. So at the 4800 you will be a little better off than I was. Overall, I think you will like the combo and it will do what you want.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: well im now in the tunnel ram club- i have a question [Re: Ari440] #1183437
09/04/12 11:27 PM
09/04/12 11:27 PM
Plano, TX
68440fish Offline
68440fish  Offline
Plano, TX
5 1/2 tall sixpack scoop on my old MAZ liftoff hood
the 4 inch tall scoop would not work
Ari - From the valley pan end rail mounting surface to the top of the vent tubes how tall is this intake / carb combination. I have a eddy performer RPM / 750 / drop base air cleaner that measures about 11". This touches my stock hood. I want to step up to a combo that measures 16", I am wondering what that will fit under.
Michael Plano, TX 68 Barracuda Notch Pro Patina
Page 3 of 3 1 2 3
