Re: 67 dart wiper ?
[Re: 3ddart]
#1183379
02/23/12 10:18 PM
02/23/12 10:18 PM
Posts: 43,536 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
It actually looks like a typical 2-speed wiper motor. So your car is orginally a 67 and you made it a 68 clone? I also assume you have the original 67 switch too?
JB Rhinehart, Realist
A-Body's RULE!
Re: 67 dart wiper ?
[Re: 3ddart]
#1183381
02/24/12 12:49 PM
02/24/12 12:49 PM
Rhinodart
Rhinotruck
Rhinotruck
No problem Dave! So you had a three speed to begin with, that answers the question. Definitely a different switch for a 2-speed, and 67's are unique also. I assume you are still using the 67 dash wiring harness? There can be some differences in the switch wiring. Let me know what you need, I am sure I have a few of the correct switches laying around. I checked the parts manuals and the switch part numbers are as followed: 67 2-speed 2820525 68 2-speed 2864415 67 and 68 3-speed variable 2770378 So you can see that they indeed change from 67 to 68 for the 2-speed motor. All A-Body 3-speed motors are also variable and have the same part number for 67 and 68.
A-Body's RULE!
Re: 67 dart wiper ?
[Re: 3ddart]
#1183383
02/24/12 11:13 PM
02/24/12 11:13 PM
Rhinodart
Rhinotruck
Rhinotruck
The one year only motor is for the 3-speed variable, the 2-speed motors are the same as far as I can tell. I will have to check and see if I have a 67 2-speed switch.
A-Body's RULE!
