Crane Iron Rockers Question #1183337
02/21/12 09:24 AM
02/21/12 09:24 AM
Merrill, WI
440CIVIC Offline OP
440CIVIC  Offline OP
Merrill, WI
Can the Crane iron rockers handle 6500-7200rpm blasts with a solid flat with 140/350 spring pressures & .515 lift? Or should I just go with Harland Sharp to be safe? I love my Sharpe's on my 440, 6500rpm everytime it gets started & after a year the lash is still dead on. The new rockers will be on a 11:1 iron headed, tunnelramed 383.
Thanks.
Re: Crane Iron Rockers Question [Re: 440CIVIC] #1183338
02/21/12 03:38 PM
02/21/12 03:38 PM
The H.S. are way better If you go with the ductile iron rockers you need the proper shafts to avoid galling the shafts and rockers up
Re: Crane Iron Rockers Question [Re: Cab_Burge] #1183339
02/21/12 05:31 PM
02/21/12 05:31 PM
Utah
topbrent Offline
topbrent  Offline
Utah
Preferences, but I like the simplicity and strength of properly bushed ductile iron rockers.
http://www.dvorakmachine.com/rockerarms.shtml
Re: Crane Iron Rockers Question [Re: 440CIVIC] #1183340
02/21/12 06:19 PM
02/21/12 06:19 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I'm using a set of Crane iron rockers with no problems.296/557 Mopar cam with Comp springs at 380#.I spin the engine to 6500 with no problem.They will work just fine.
Nautilus Racing-
Re: Crane Iron Rockers Question [Re: Chris2581] #1183341
02/21/12 06:24 PM
02/21/12 06:24 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
what shafts chris?
74 dart sport 440 www.Csucarbs.com
Re: Crane Iron Rockers Question [Re: shoebox] #1183342
02/21/12 06:36 PM
02/21/12 06:36 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
What size is the cam? Seems like alot of rpm for the size of that cam.
67' charger 499 RB 10.57 at 127
Re: Crane Iron Rockers Question [Re: topbrent] #1183343
02/21/12 07:11 PM
02/21/12 07:11 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
but that kit uses a reduced diameter shaft I wouldn't want a smaller shaft it would cause more flex.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Crane Iron Rockers Question [Re: dusturbd340W5] #1183344
02/21/12 07:17 PM
02/21/12 07:17 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I used to run the iron rockers with a crane R280 roller, i now use the same rockers with mopar .590 but 6500 max now.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Crane Iron Rockers Question [Re: deaks] #1183345
02/21/12 08:00 PM
02/21/12 08:00 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
deaks are your iron rockers "stock" outta the box?
Re: Crane Iron Rockers Question [Re: 440CIVIC] #1183346
02/21/12 08:25 PM
02/21/12 08:25 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
It will be fine. I use to run my 383 to 7000 with the Isky ductile iron units. Those use to be the standard years ago and guys ran them with rollers all the time. Get the right shaft.
Re: Crane Iron Rockers Question [Re: BSB67] #1183347
02/21/12 08:33 PM
02/21/12 08:33 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Not sure, they have proper spacers, not springs, i'm not even sure if they're crane or isky, they have a flat screwdriver slot on the adjuster.
I've had a rocker back out before, only did superficial damage, they look very sturdy, compared to the alloy ones. That's why i stick with them.
Mick
best 60ft 1.36
Re: Crane Iron Rockers Question [Re: shoebox] #1183348
02/21/12 08:49 PM
02/21/12 08:49 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
what shafts chris?
Got them from Ed Hamburger YEARS ago.
Nautilus Racing-
Re: Crane Iron Rockers Question [Re: Chris2581] #1183349
02/21/12 10:24 PM
02/21/12 10:24 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
I've been using the same set of Crane Ductile rockers for 10 years now in my 446 with a comp 650 lift flat tappet , with no issues. I shift at 6800.
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: Crane Iron Rockers Question [Re: 65dragnet] #1183350
02/22/12 01:10 PM
02/22/12 01:10 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
Whats the secret to not gall the rockers? Plenty of oil yes.. But
It seems like some guys never have any issues and others burn up
Adjusters, gall rockers, seizing on shafts etc Id like to have the
Durability of iron and keep the cost down not being bushed
