Balancing necessary? #118330
09/09/08 05:34 PM
09/09/08 05:34 PM
FarDarter Offline OP
I'm planning on doing a hone and re-ring of my 318 shortblock that is totally mid-seventies Dart stock. I'm going to top it with some 302 heads and as I understand it, that will lower the compression a small amount beyond how low it already is. So, if I were to go ahead and get some new pistons to bring it up to around 9.0:1 is there any chance I could get away with runnning it without balancing? Since every car build seems to have a name these days, you can go ahead and call this one "Cheap."
Re: Balancing necessary? [Re: FarDarter] #118331
09/09/08 05:50 PM
09/09/08 05:50 PM
dogdays Offline
dogdays  Offline
302 heads have smaller chambers than the '68-and-up 318 open chamber heads. As you will most likely be replacing a steel shim gasket with a composition gasket twice as thick, gaining about 4 cc of volume, your net compression will remain the same as stock.
Replacing stock LA 318 pistons with KB167s will make necessary rebalancing the rotating assembly as the 167s weigh about 84 grams less than the stockers.
R.
Re: Balancing necessary? [Re: dogdays] #118332
09/09/08 06:20 PM
09/09/08 06:20 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
You dont "have to" have it balanced. But your going as far as you are with boring and new pistons, its only like $180 extra to have it done and it will in theory run smoother.
Re: Balancing necessary? [Re: Baxter61] #118333
09/09/08 06:50 PM
09/09/08 06:50 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
IMHO, there is no "theory" about it. I won't ever build another engine without having it balanced.
Besides, since he is changing to lighter pistons, that almost requires having the engine balanced.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: Balancing necessary? [Re: 340727dart] #118334
09/09/08 10:10 PM
09/09/08 10:10 PM
MI
marklock Offline
I tried too hard for a custom title
marklock  Offline
MI
Have it balanced, money well spent. my
Re: Balancing necessary? [Re: marklock] #118335
09/09/08 10:43 PM
09/09/08 10:43 PM
Ozark Mo.
BADBEE Offline
BADBEE  Offline
Ozark Mo.
I agree, its no theory, its fact. An engine will perform better, live longer and have less stress on all internal components when its balanced.
Re: Balancing necessary? [Re: BADBEE] #118336
09/09/08 11:01 PM
09/09/08 11:01 PM
Rome, PA
Ryan_340 Offline
Ryan_340  Offline
Rome, PA
1972 Power Wagon W100 1973 Power Wagon W200 1971 Duster 1972 Dart Swinger 3-1972 Demons
Re: Balancing necessary? [Re: FarDarter] #118337
09/09/08 11:10 PM
09/09/08 11:10 PM
New Zealand
solidcam Offline
solidcam  Offline
New Zealand
From the factory a lot of engines weren't balanced that good.You will really appreciate a good balance job and so will your engine.You may even pick up a few ponies in the process.
Re: Balancing necessary? [Re: BADBEE] #118338
09/10/08 12:20 AM
09/10/08 12:20 AM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
Ive read articles and spoke with an engine builder who was a long time endurance racer and they used to run motors in 24 hour races and do dyno testing on motors that werent balanced and they concluded there was no evidence that not-balancing as no ill effects on on engine life. I dont disagree that its money well spent, but Ive run motors that werent balanced and I had 0 issues with it. Plus, you really think factory motors from that era were balanced all that well? My buddy used to race 340's in the early 90's and he said he would pull motors apart where 1 cylinder was already bored .010 over from the factory, go figure that one out!
Re: Balancing necessary? [Re: Baxter61] #118339
09/10/08 12:56 AM
09/10/08 12:56 AM
Well the question has now become moot, as I have been corrected in my understanding of what my compression ratio is going to do. Somehow I had come to believe the 302s had larger chambers than earlier 318 heads despite the quench pads. I'm not sure how that happened but now that I know the truth, I'll be keeping my same pistons. Project Cheap just got cheaper! Thanks for the input, fellas.
Re: Balancing necessary? [Re: Baxter61] #118340
09/10/08 12:58 AM
09/10/08 12:58 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
That makes no difference to balance. Piston A is standard bore size and the same piston in a .03 will weigh the same. They make them like that just so you can avoid the rebalance issues if you kill an individual piston/cylinder.
Re: Balancing necessary? [Re: DaytonaTurbo] #118341
09/10/08 01:19 AM
09/10/08 01:19 AM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
I never knew that
Re: Balancing necessary? [Re: Baxter61] #118342
09/10/08 01:44 AM
09/10/08 01:44 AM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
Factory OEM "balancing" ? ..... some I have heard from people I know are as much off as 50 grams ! ...and from a Bud in FL ...as much as 90 grams !!! ......... And a 300$ balancing job OFF as much as 30 grams !!!!
It ALL depends on who is doing the balancing job. I did a 383 some years ago with a grams scale and did EACH to within 2 grams. And that did not take that much work to do.
