Hemi valve cover grease pencil numbers
#1183326
02/21/12 09:23 AM
02/21/12 09:23 AM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
I know this has been discussed before, but I haven't been able to find the thread.
On the front of the valve covers is the last couple digits of the part numbers (with auto or manual linkage) in white grease pencil on a Hemi, black on the rest.
What are the correct numbers for the front of a 68 Hemi with an automatic? Lynch Road car.
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Hemi valve cover grease pencil numbers
[Re: Ply72rr]
#1183328
02/22/12 04:46 PM
02/22/12 04:46 PM
Kowal
Charlotte, NC
Here is a pic I snapped of a recently restored Hemi in a 68 Dodge. An automatic.
I wasn't sure of this number, I have seen numbers on survivor Hemi's that were different.
[Re: Kowal]
#1183329
02/22/12 04:52 PM
02/22/12 04:52 PM
Kowal
Charlotte, NC
Here is a survivor pic of a Hemi in a 69 Dodge, this one a 4 speed car. Picture is from a thread on the Lift Off Hood forum which I hope they don't mind that I borrowed for this.
[Re: MMC Detroit]
#1183331
02/23/12 12:33 AM
02/23/12 12:33 AM
Posts: 12,085 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I thought that the engine code was on the front of the pass vc, the tranny code was on the front of the driver vc, and the carb code was on top of the driver vc. All coded off the broadcast sheet. And those codes could very well vary from year to year. Do I remember right?
Master, again and still
[Re: 68jim]
#1183334
02/23/12 10:03 PM
02/23/12 10:03 PM
Posts: 511 AZ.
696pack
AZ.
I'm curious about this as well for my 68 Hemi RR auto. I have a copy of a buddies 68 4 speed Hemi RR and his engine code is 733. (do not have mine...) I can't see the trans code since a rusty seat spring covered that block . So is 734 the code for 68 hemi Auto? And that code is displayed on the pass side valve cover?
Take a no. 2 pencil eraser and ligthly erase the rust mark. It sometimes works where you can read the code under it. It works for the grease pencil marks too as the grease pencils has graphite in them which is what is in pencil lead.
[Re: 69CoronetRT]
#1183335
02/23/12 11:26 PM
02/23/12 11:26 PM
Kowal
Charlotte, NC
Are you positive this car was/is a four speed?
(9)22 would be the engine assembly code for a 69 Hemi with automatic.
(9)21 would be the code for a four speed car.
. Checked, original owner had a second, automatic, car. Probably swapped valve covers.
[Re: 696pack]
#1183336
02/24/12 02:16 PM
02/24/12 02:16 PM
Posts: 1,029 Southeast Virginia
68jim
Southeast Virginia
I appreciate the tip, however in this case my copy of his sheet is a scan...
So back to the topic - The engine numbers are on the driver side and not the passenger side? The posted picture showed a three digit number, my memory is not that great anymore but I seem to recall usually seeing just a two digit number there.
