Will my dart run with the dash cluster removed ? #1182937
02/20/12 05:26 PM
02/20/12 05:26 PM
Lyons, CO
MileHighDart Offline OP
Lyons, CO
Just wondering, I'm working on paint and interior stuff. I want to remove the dash cluster, and then the whole dash to paint it, but I dont want the car to be dissabled. I'd still like to move the car outside when working on other things.
Is this possible ?
Re: Will my dart run with the dash cluster removed ? [Re: MileHighDart] #1182938
02/20/12 05:40 PM
02/20/12 05:40 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yes will work fine. I usually leave the wiring with the dash when I pull it, but in this case you'll need to leave it with the car. Also, you'll have to bolt together the two ammeter wires if you want the battery to charge.
Re: Will my dart run with the dash cluster removed ? [Re: DaytonaTurbo] #1182939
02/20/12 05:50 PM
02/20/12 05:50 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Yes Also, you'll have to bolt together the two ammeter wires if you want the battery to charge.
Yep...and worth wrapping them with abit of electrical tape after you bolt them together...just to stop any chance of accidently shorting them to ground while they or you move stuff around them while working.
Re: Will my dart run with the dash cluster removed ? [Re: OzHemi] #1182940
02/20/12 05:58 PM
02/20/12 05:58 PM
Lyons, CO
Lyons, CO
Thanks guys, thats good news.
Re: Will my dart run with the dash cluster removed ? [Re: DaytonaTurbo] #1182941
02/20/12 06:10 PM
02/20/12 06:10 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You need to bolt those two together just to make it run.... But yeah it'll run... I took a 150+ mile trip with no dash in the early eighties....
