Thermoquad geyser! #1182899
02/20/12 03:56 PM
02/20/12 03:56 PM
Northern Virginia
Moparmaniacc Offline OP
Northern Virginia
Since I was off today I decided to try out the '76 thermoquad I bought off ebay. I got lazy and just installed it, because it looked so clean and untouched. Motor started up fairly quickly but then I peered thru the hood opening and saw fuel gushing out of the bowl vent tube! I shut it down and cleaned up the gas mess. I guess that means the float is saturated and sunk to the bottom, or the level needs adjusting? Anything else that could have caused it?
Re: Thermoquad geyser! [Re: Moparmaniacc] #1182900
02/20/12 04:25 PM
02/20/12 04:25 PM
IMGTX Offline
IMGTX  Offline
Remove the top for a look.
Could be the needle & seat are shot.
Could be a stuck float.
Could be a bad float.
Could be parts are missing.
Don't forget there are two screws inside the choke airhorn.
Re: Thermoquad geyser! [Re: IMGTX] #1182901
02/20/12 08:39 PM
02/20/12 08:39 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
There are 2 O-rings between the plastic bowl and cover. If they're shrunk the bowl will overflow.
Doug
Re: Thermoquad geyser! [Re: Moparmaniacc] #1182902
02/20/12 09:04 PM
02/20/12 09:04 PM
replace the needle/seat assy's and adj float levels. Might be able to wipe the needle neoprene tapered tip with your thumb to clean/smooth it. blow the 2 seats clean check the brass seats for snugged then install the 2 rubbed clean needles then the float assy's.
Re: Thermoquad geyser! [Re: dvw] #1182903
02/20/12 09:13 PM
02/20/12 09:13 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Doug [/quote
Actually it won't overflow because of those... It will run crazy rich but not overflow... That has to be an issue with the needles & seats or floats... I never trust an old carb till I've looked inside...
Re: Thermoquad geyser! [Re: 1_WILD_RT] #1182904
02/20/12 10:04 PM
02/20/12 10:04 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yep, best "Blind guess" is a stuck float/needle/seat issue.
Re: Thermoquad geyser! [Re: ScottSmith_Harms] #1182905
02/20/12 10:10 PM
02/20/12 10:10 PM
Northern Virginia
Northern Virginia
Thanks for the advice. I have heard about the O ring problems with these carbs. Unfortunately I have to wait till next week before I'll have time to tear it apart...
Re: Thermoquad geyser! [Re: 1_WILD_RT] #1182906
02/20/12 10:29 PM
02/20/12 10:29 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug [/quote
You're correct brain dead on my part. I was just thinking rich.
Doug
Re: Thermoquad geyser! [Re: dvw] #1182907
02/22/12 01:19 AM
02/22/12 01:19 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Doug
Would it come out the top?
NAPA sells brass floats.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
