Help! No headlights! 1973 Road Runner
#1182752
02/20/12 01:54 PM
02/20/12 01:54 PM
Posts: 1,102 Salem, OH (Quaker City Raceway...
GuruRanger
I'm trying to get my '73 Road Runner rust-bucket back on the road. It's been down since around 1994. I fixed the oil pan, brake lines, floor pans, and was ready for a Friday night test run...almost. Now there's no headlights! Two trips to the auto parts store later and I have a new dimmer switch and new headlight switch, but still no headlights. I now have marker lights, but no headlights(yes, I did pull the knob out all the way! ). Am I missing something here? Inline fuse or something that would affect headlights but not affect marker lights, or is the only possibility a faulty plug at the headlight switch or at the dimmer switch?
Re: Help! No headlights! 1973 Road Runner
[Re: SattyNoCar]
#1182758
02/20/12 07:37 PM
02/20/12 07:37 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Dimmer switch does not need to be grounded, parking lights & tail lights ground through their mounting bolts, headlights need separate ground wires which will be bolted to the radiator support typically near the battery ...
[Re: 1_WILD_RT]
#1182759
02/20/12 09:19 PM
02/20/12 09:19 PM
RapidRobert
I'd jump fire to the pull apart connector at the dr headlight area (not sure exact loc on '73 RR)/into A bodies only) & see if the brights and dims work (2 wires) which tells you the bulbs/sockets/grounds are good & if good then the next connector upstream probably the bulkhead. If hot there (2 wires 1 for brights 1 for dims) then further upstream to the next connector which'd be the dimmer sw & 1 terminal should be hot with the headlight sw on & 2 terminals 1 to brights 1 to dims. If good there go to the headlight sw.
