Re: Hughes Whiplash cam + Comp Cams springs/lifters?
[Re: dogdays]
#1182544
02/20/12 09:44 PM
02/20/12 09:44 PM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
The Comp Thumpr cams are the original, the Hughes are their take on the Thumpr. I'd look at the Comp cam, see what they use. Hughes is notoriously hard to deal with if you don't do exactly what he says and there's a significant difference in the springs. I wouldn't chance it.
R.
Heh... well thats not exactly a glowing recommendation... haha. I'll check that out.
I suppose i could just sell the stuff i have, or maybe just the springs to make up some dough.
[Re: BIGSTROKER]
#1182546
02/20/12 11:05 PM
02/20/12 11:05 PM
Pale_Roader
Swears too much
Swears too much
Okay, this is where i get confused...
I looked up the Comp Thump'r, there are 3, from a 227/241 to a 235/249 to the big 243/257. The Whiplash is 232/245, yet it has more lift than the biggest Thump'r. Is it the lift, or the duration/ramp profile that dictates the spring needs? The Comp Cams springs recommended are close to what i have. The 995-16 spring (recommended for all 3 Thump'r's), which has the same seat and .550" rates as mine, but an extra 50lbs rated 'rate'.
I assume the Comp is using a less aggressive ramp than the Hughes? Is that why i need more seat pressure?
One more thing. On my box i have right here, the 924-16 spring is rated at 297lbs, yet i just looked on Comp's site and there its rated 347lbs. Which is which? The spring is stronger than i thought it was. Or did they change the specs in the 10 years since i bought these?
[Re: Pale_Roader]
#1182547
02/21/12 03:42 PM
02/21/12 03:42 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
FWIW, I run the Whiplash cam. 229/242 at 0.050, 518 lift, 107 LSA. This is on my 383 with 346 heads milled 0.030, ported/blended, 3 angle valve job, stamped steel rockers. No other mods to the heads. Am using the same springs that I used with the Comp Cam XE262, the one that is recommended by Comp Cams for the 262. Running the Hughes lifters with the cam. The engine runs strong to 6000 RPM. May go higher with no problem, don't know, that's where is shift.
[Re: Junky]
#1182548
02/22/12 07:56 AM
02/22/12 07:56 AM
Pale_Roader
Swears too much
Swears too much
Okay, again i am confused...
Just comparing Comp cam/springs to Comp cam/springs here and leaving Hughes outta this...
The springs spec'd for your XE262 cam (either set, there are two options) are stiffer/rated heavier than the springs spec'd for the Comp cam XE275High-Lift cam i bought my springs for. Shouldn't a considerably stouter cam need stouter springs...??? Something's amiss here.
Either way, its looking like a possible go. Not optimal... but doable. The springs i have were spec'd for an aggressive ramp lobe (again, Comp XE275HL - 231/237 @ .050 and .525"? lift). In fact, ALL the high-lift Comps 'recommend' that spring, even the XE295HL (251/257 and .564" lift).
i think i'm overthinking the original question now... especially seeing how well some seemingly mis-matched combos work, but now its the spring recommendation questions that have me wondering. Anyone...???
[Re: Pale_Roader]
#1182549
02/22/12 03:01 PM
02/22/12 03:01 PM
Junky
Wherever I am.
All I can tell ya is what I've done and learned. I'm running the recommended springs for the XE262. If you look at the Comp Cams web site, at the XE cams, you'll see they post part numbers for lifters and springs and stuff for each cam. Look at the springs part number for the XE262 and you'll see that it's the same part number for the next two larger cams (maybe it's three larger cams, I can't remember) which are "bigger" than the 262.
I called Comp Cams and asked them questions concerning that particular part number and told them what cam I was going to install. They told me no problem.
So I left the springs on the heads and swapped the cam. Engine runs great. I've taken the engine to 6000 RPM many, many times now. Buzzes right up there. It loves it.
BTW, I forgot to say that the pistons (flat top) are 20 in the hole. Also run the steel shim head gaskets.
Call Comp Cams and talk to them.
[Re: Junky]
#1182550
02/22/12 03:55 PM
02/22/12 03:55 PM
dogdays
Here we go with the cam stuff: The way to get more lift per degree of duration is to have a faster acceleration rate. The maximum acceleration rate varies with the diameter of the lifter. Over the past 10 years or so the cam designers have found ways to use a really fast accel rate on the opening with a slower closing rate to set the valve back down so it doesn't bounce. The standard of the automotive world, the chevy smallblock, has lifter dia. 0.842". Thus you will find that about 90% of all lobes are designed around that limitation. We call them "Chevy lobes". You can tell this in cam catalogs when the lift and duration at 50 lift are the same for all engines with a 1.5 rocker ratio.
One of the advantages designed into Mopar engines is they have a lifter diameter of 0.904" That means if the cam designer wants to he can accelerate the valve faster. This means more area under the lift vs duration curve and more power. For years Hughes has used what it calls "real Chrysler lobes". These take advantage of the larger lifter. The latest Hughes lobe series is closer to the edge than about anyone else. You can see this when the lift for same duration at 50 is higher on the Hughes grind. So it makes sense that it would take more spring to slow down the faster-moving valve and turn it around. One does not want the lifter to fly off the cam lobe (except in certain very specific cases with lift rules).
Now onto springs: There are only a few really pertinent numbers for springs. They are seat pressure at a particular installed height, coil bind height and spring rate. For example, the Crane 933 springs I am going to use on my 318 project have a seat pressure of 98 lb at 1.700" installed height and spring rate of 328 lb/in. I am going to install them at 1.600" so I have to add the spring rate times the extra compression, in this case it is 328 x 0.100 = 32.8, to the 1.700 seat pressure so now my installed seat pressure is 130.8 lb, perfect for hydraulic roller lifters. Assuming I use a 0.474 lift cam, the open pressure is 130.8 + (0.474 x 328) = 286lb open pressure, in the ballpark for hydraulic roller lifters. Coil bind is 1.08", so 1.08 + .474 + 0.060 = 1.614 which is more than my 1.600 installed height meaning this might not be the spring for the job because one can't run really close to coil bind as it will destroy the spring. In this case I will be saved because my stock rockers come in with less than 1.5 ratio, a 1.45 is more like it, real lift is 0.458 so the springs will have more than the 0.060 minimum clearance between max lift and coil bind.
If you think about it, the same spring can have many different seat pressures depending on installed height, which could explain the different ratings on the same spring.
R.
[Re: dogdays]
#1182551
02/23/12 07:15 AM
02/23/12 07:15 AM
Pale_Roader
Swears too much
Swears too much
Well now i feel bad that you typed all that out. I'm way ahead ov you here. The saving grace with what i have i think is that is was spec'd for the Comp version/ripoff ov the Hughes cams. The 924-16 springs are what Comp recommends for their 'Mopar .904" lobe' cams, even the big one.
R.
Man... i used to know all this stuff... its been a looong time since i had my head in the cam books...
Anyways, so what you're saying is that as long as i can stay further than .060" from coil bind, i can shim the springs i have for a bit more seat pressure?
The 924-16 spring is a dual-spring. With an installed ht ov 1.900", and coil bind at 1.175", that gives me .725" to play with... minus .060", so .665"?
IF i install it at 1.800" (by my handy-dandy Comp catalog here), the 924-16 is now 137lbs... closer to the 150lbs Hughes springs seat at. That also brings the pressure at .500" lift to 311lbs. The Hughes springs are 325lbs at .500" lift. I assume this means my 'new' coil bind is .625"? Since the lift ov the Hughes cam is .518", that still gives me lots ov room.
Am i close? or is the math not so linear in all this...??? I'm just trying to understand the math now.
[Re: Pale_Roader]
#1182552
02/23/12 09:03 PM
02/23/12 09:03 PM
Pale_Roader
Swears too much
Swears too much
R.
Come on... this is engines 101 for most ov you guys...
Anyone...???
[Re: Pale_Roader]
#1182554
02/24/12 06:53 PM
02/24/12 06:53 PM
dogdays
There are three different things going on here. First, the Comp Thumpr cams came out at least 6 months before Hughes' Whiplash. I believe that the Whiplash was a response to the Thumpr and in typical Hughes fashion they did it just a little better. As you yourself noted the Hughes "real Chrysler" cam has more lift per degree of duration. It sounds like the Comp is one more Chevy lobe on a whatever core. Also, the quicker rate of lift for larger diameter lifters is not a Hughes secret, it's an early Machine Design principle. So to say that the Comp is in any way a ripoff of Hughes is laughable. It just took Comp a little longer to see the market for the lobe, they probably let Hughes do their market research for them. Again, this is common in the competitive world of industry. Okay, now on to second point, you may have old springs where the part number stayed the same but the spring itself was changed slightly (upgraded) over the years. So I'd believe what's on the box they came in. And yes, springs are blessedly linear and your math looks right. Third, I am about as cheap as they come and the more I think about this the more I think you will be all right without spending the extra $$$$. Keep in mind to break the cam in to Hughes specs, including removing the inner springs. Then be careful in the upper rpm ranges where the springs might possibly allow valve float or bounce earlier than a stiffer spring. As for the lifters, they all come from just a couple of places, as long as the oil doesn't come squirting out around the lifter it should be OK.
Keep us posted on your results... R.
[Re: dogdays]
#1182556
02/24/12 09:47 PM
02/24/12 09:47 PM
Pale_Roader
Swears too much
Swears too much
There are actually three different cams noted in this thread too though... The Thump'r, Hughes, and the Comp 'Mopar lobe' XE/HL cams. The Thump'r still seems to use the old Chevy style lobes, i had no interest at all in those, they were just mentioned.
Yeah, i think Ultradyne was doing it before either ov them?
Someone locally said the same thing, i was just comparing the spring rates on the box they came in with the rates in the catalog... which i got around the same time i got the springs. Its a 2002 catalog, which is when i bought all that stuff.
Anyways, if there is nothing weird i need to know about the math (linear, as you said), then i can probably figure this out from here. I am looking forward to buzzing this thing... so i hope i dont screw myself being cheap. But the whole concept is temporary... while i get this car's real engine sorted out. This will keep me on the road for a year or so hopefully.
Thanks.
[Re: maximum entropy]
#1182557
02/24/12 09:50 PM
02/24/12 09:50 PM
Pale_Roader
Swears too much
Swears too much
my chiropractor urged me to avoid whiplash cams. just get a purple shaft (which is what everyone is emulating here) and be done with it.
Hah! I sure hope you're kidding...
