measuring main bearing crush
#1182512
02/20/12 02:44 AM
02/20/12 02:44 AM
Posts: 4,179 California
mickm
California
i'm putting together a hemi, and a friend who is a builder was asking about the bearing crush, so i took each cap, put in the bearing, and brought the cap close to seating with both bolts, and then tightened only one side to 60 ft lbs. i then measured the distance between the cap and the block on the other side, and got the following measurements, 1-5.
.004 .006 .005 .005 .006
this seems like a lot, but i was wondering how accurate this is with the cross bolt of the inner mains, if that would get in the way of the cap being able to come close down and show the actual crush.
does this work on a hemi block? is this the correct way to check this?
Re: measuring main bearing crush
[Re: mickm]
#1182513
02/20/12 03:20 AM
02/20/12 03:20 AM
Posts: 43,296 Bend,OR USA
Cab_Burge
No
[Re: Cab_Burge]
#1182514
02/20/12 03:48 AM
02/20/12 03:48 AM
Cab_Burge
There are specs. on the main bearing bore sizes, usually they allow .001 or less varience, to get how much crush the main caps are affecting your bearing you can measure the inside bore of your block with the main caps tighten down without the bearings in them and then measure the thickness of each bearing, add the two thickness together and then install them into the mains with the caps tighten down, measure the I.D. and see how much clearance you have. Subtract the bearing thickness from I.D. you meausred and the difference is the amount the bearings cruched in the block, I think It should be less than .0010 I think thats the proper way I worry about the total clearnances as long as the bearings do not move around in the bores easily, they should snap in and stay there That is the crush as I see it
[Re: Cab_Burge]
#1182516
02/20/12 11:33 AM
02/20/12 11:33 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
There are specs. on the main bearing bore sizes, usually they allow .001 or less varience, to get how much crush the main caps are affecting your bearing you can measure the inside bore of your block with the main caps tighten down without the bearings in them and then measure the thickness of each bearing, add the two thickness together and then install them into the mains with the caps tighten down, measure the I.D. and see how much clearance you have. Subtract the bearing thickness from I.D. you meausred and the difference is the amount the bearings cruched in the block, I think It should be less than .0010 I think thats the proper wayI worry about the total clearnances as long as the bearings do not move around in the bores easily, they should snap in and stay there That is the crush as I see it
that's all I've done too. if they "click" into place and stay there, then I torque the caps and measure them, then the journal, to know my bearing clearances.
**Photobucket sucks**
