4-Speed Install, Muscle or Jack
#1182219
02/19/12 06:04 PM
02/19/12 06:04 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
What do you guys prefer? Engine is out of the car so I am going to do a mock-up, but when you are under the car, what do you prefer?
Thanks.
383, Hemi 4-Speed, AlterKtion, D60
Re: 4-Speed Install, Muscle or Jack
[Re: Mr.Yuck]
#1182221
02/19/12 06:18 PM
02/19/12 06:18 PM
Crazy68Dart
Canton, Ohio
... and in my case safer. I'm not that big of a guy. This is a cast iron 4-speed.
I was looking at the jack adapters that you remove the pad off a standard jack and replace with a transmission adapter. There is one that seems adjustable which might work. Need to look around some more.
[Re: Mr.Yuck]
#1182222
02/19/12 06:20 PM
02/19/12 06:20 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
I've done auto trans on my back way back.. muuuuuchhhh easier w/ a jack. I'd use a jack.
Definitely use a jack. For the life of me though- why couldn't the trans manufacturers cast the case with a flat pad on the bottom that would sit on a trans or floor jack without tipping over or wanting to fall off all the time
[Re: TooMany62s]
#1182226
02/19/12 09:44 PM
02/19/12 09:44 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I've always rassled them in and out by hand, but I sure would like one of them jacks.
[Re: Supercuda]
#1182227
02/19/12 09:55 PM
02/19/12 09:55 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
A jack for sure. I have never muscled one in on back, and never will. I have a old floor trans jack that has a large flat pad, but as stated, the way the case is, it just wants to flop around. I would build a simple adapter just for the 833'2 because of this. I have done them on a regular floor jack too, but its a little unnerving when it get some height and I have had them fall off before---thus me reasoning for building a simple and specific adapter. I bet it would cost less than $20 in materials to make.
Outcast Dodge guy.
[Re: 85_Ram_4speed]
#1182228
02/19/12 10:18 PM
02/19/12 10:18 PM
Crazy68Dart
Canton, Ohio
Gus, you've always got my back, I appreciate it. I'll let you know. I was going to go over to HF and see what they have. I hate supporting that place... but all this stuff is imported, so I guess I'll avoid the mark-up. For, you guys that made the custom adapters? I was thinking about fabbing a small cradle of some sort that followed the contours of the case. Is this how you did yours, or you have brackets, etc. that use some existing holes in the case? Thanks!
[Re: TooMany62s]
#1182231
02/20/12 11:33 AM
02/20/12 11:33 AM
Posts: 1,565 tennessee
pushbutton
tennessee
I bought one of these cheapies from Harbor Freight. I've used it for 833's five or six times. Much easier than muscle especially if your old, like me.
I have one of those too. Know what you mean about the old part also.
[Re: Crazy68Dart]
#1182233
02/20/12 12:30 PM
02/20/12 12:30 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Thanks.
when I was a younger man, I used to bench press them in. It only took a few seconds. Then one day, few years ago, I tried the same tactic. I almost had it and then I couldn't hold it and it landed on my chest. I couldn't get it off. My wife had to rescue me.
So now its a jack and 3 assistants. Takes longer but it sure is safer.
[Re: Moparnut426]
#1182236
02/20/12 01:28 PM
02/20/12 01:28 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
833, I've never worked with, but hear they are heavy!! I'd use a jack. 727, I used a jack. T-56, I slid under the truck, tipped the gearbox up and slid myself under it, then pulled it up onto my chest, then I benchpressed the gearbox up into the bell housing and into position. it was very easy, but that gearbox even though it's big, only weighs about 70-75 lbs. I probably push more weight than that when I'm doing a pushup, and for my annual fitness test I have to knock out about 60 in a minute I did my NV3500 the same way, it's about the same as the T-56 as far as weight, but has that big ole bell housing cast into the case...actually made it easier. gave a nice solid "handle" to grab it and secure the trans with a good grip to angle and wiggle it into position through the clutch. never thought about losing an eye doing it, but ouch, and yea, I could see that happening. I never pushed up though, unless I had a very firm grip on the gearbox first, and felt like I could maneuver it around as needed. as I get older though, and not as strong...I may find myself suing hydraulics more and more
**Photobucket sucks**
