Another magnum motor question #1182112
02/19/12 01:16 PM
02/19/12 01:16 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
I picked up a 5.9 magnum motor for the wife's Dart project. I know that i will have to change pans and pickups, but i was also wanting to put the original stle(72) pulleys and acceceries on. Can i just use the older sylye timing cover and water pump? The old drive brackets? And what do i do about the harmaonic balancer? Can you use the LA stlyle balancer and pulley off of a 360?
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Another magnum motor question [Re: rattler] #1182113
02/19/12 01:35 PM
02/19/12 01:35 PM
Andrewh Offline
Andrewh  Offline
the whole front end does bolt up, pulley's and all, BUT the harmonic is different.
I don't think you can reuse the LA stlye.
you will have 1 bolt that doesn't line up on the crank pulley.
Re: Another magnum motor question [Re: Andrewh] #1182114
02/19/12 03:41 PM
02/19/12 03:41 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
The serpentine pulley appears to be part of the harmanic balancer, that is why i thought that i might be able to use a regular LA style harmonic ballancer-pulley setup.
Re: Another magnum motor question [Re: rattler] #1182115
02/19/12 04:45 PM
02/19/12 04:45 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
To use your stock stuff you need a cam snout extension from Hughes. as far as the crank pulley Get you a balancer from a earlier MAG 5.9 & put it on & bolt your pulleys up 1 hole can be burred out to fit the sixth bolt. To use your stock Alt brackets you will need to grind a boss on the head down or move the tab on the bracket
Re: Another magnum motor question [Re: BulletBob] #1182116
02/19/12 04:47 PM
02/19/12 04:47 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Which intake are you using?
Re: Another magnum motor question [Re: rattler] #1182117
02/19/12 04:53 PM
02/19/12 04:53 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
I stuck the entire LA front end on the 5.9 I built for my Charger. I used the 318 timing chain cover, LA water pump, damper and all the accessories. I eliminated the mechanical fuel pump and am going with an electric one.
I have not started it yet but so far everything looks good to go. I hope to fire it up in the next two weeks.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Another magnum motor question [Re: dfsmopars] #1182118
02/19/12 05:44 PM
02/19/12 05:44 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
I haven't decided which intake carb combo to run yet. This will be a mild set-up for the wife. But, back to one of my questions, can i use an early LA 360 balancer?
Re: Another magnum motor question [Re: rattler] #1182119
02/19/12 08:30 PM
02/19/12 08:30 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Maybe someone else can confirm, but I think the magnum and LA 360's are balanced differently, which is why you can't use an LA balancer.
Re: Another magnum motor question [Re: DaytonaTurbo] #1182120
02/19/12 08:51 PM
02/19/12 08:51 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
They do balance different that's why I posted about using A earlier 5.9 Mag balancer
Re: Another magnum motor question [Re: BulletBob] #1182121
02/19/12 08:56 PM
02/19/12 08:56 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
If you go back with the V belt drive that came with the car You will need the Crosswinds intake or the Dual plane from MP for a Mag. This way you can use factory off the shelf bypass hose & such.
I've done this swap a few times
Re: Another magnum motor question [Re: BulletBob] #1182122
02/19/12 09:09 PM
02/19/12 09:09 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
What year balancer would i need Bob?
Re: Another magnum motor question [Re: rattler] #1182123
02/19/12 09:17 PM
02/19/12 09:17 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
94-mid 99 I had to change the balancer on my 2000 R/T Dak to use a true underdrive pulley kit.. if there's any problems or questions I can help you. I've done the LA to Mag swap in different cars & trucks about 8 times or so in the last 5 years. 518 swaps too.
Re: Another magnum motor question [Re: BulletBob] #1182124
02/19/12 09:57 PM
02/19/12 09:57 PM
Andrewh Offline
Andrewh  Offline
97 I thought was the cut off year. they change in 98, but could be just electrical.
Re: Another magnum motor question [Re: Andrewh] #1182125
02/19/12 10:21 PM
02/19/12 10:21 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The electrical changed every time the 518 had changes it looks like to me. Some trans shops will put a 2 pin or 3 pin valvebody in a 46RE.
Re: Another magnum motor question [Re: Andrewh] #1182126
02/19/12 10:24 PM
02/19/12 10:24 PM
Crofton, Ky.
rattler Offline OP
rattler  Offline OP
Crofton, Ky.
I was looking at online parts sources and it listed 94 thru 03 as one part, and 93 back to 79 as being another balancer. I am just trying to round up the right parts before i need them.
Re: Another magnum motor question [Re: rattler] #1182127
02/19/12 10:40 PM
02/19/12 10:40 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
That's correct 93 and back LA 360's used a different balancer (IIRC) than 94+ 5.9 Magnums. That is because the Magnum used a different crank, with lighter rods and pistons than the old 360 LA did. I'd be concerned that bad things will happen if you try and mix/match them.
Are you sure the serpentine pulley won't come off of the Magnum balancer? I'm having a hard time visualizing that the pulley and balancer are one part... (balancer is iron and the pulley, stamped steel)?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Another magnum motor question [Re: GO_Fish] #1182128
02/19/12 10:48 PM
02/19/12 10:48 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
If I remember correct the reason that I changed the balancer on my Dak because the pulley & balancer was two piece pressed together. I know I changed the WP to a bolt on pulley style (92-96) so the pulleys would work
Find the balancer & put it on & ride.
Re: Another magnum motor question [Re: BulletBob] #1182129
02/19/12 11:12 PM
02/19/12 11:12 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
Alright, let me get this straight. With a '94 block, stock crank, KB pistons and an externally balanced flex plate from a Magnum, the LA damper from a '72 318 will not be good? What will happen? Is there a catastrphic imbalance or an annoying vibration? Is it something I can break-in the engine with and change later if I recognize a problem? I have everything put together and you have my gotten my attention.
Re: Another magnum motor question [Re: dfsmopars] #1182130
02/20/12 01:20 AM
02/20/12 01:20 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
You are asking for trouble, that thing is gonna be way out of balance.
One...the KB pistons are lighter than stock.
Two the magnum and LA are balanced different on the front and back of the eninge.
When I was 19 I built a 360 once without balancing it and used the KB 107 piston, 360 rods, 360 crank and at first used 360 balancer and converter weight, vibrated real bad and ate HP. I got told to balance it, instead I looked up the weights and figured it would be closer to a 5.9 balance factor, put in a neutral converter a 5.9 plate and damper and it was better but still bad, finnally pulled it all, balanced it properly and no other changes it felt smooth as glass and felt like another 50 HP, so now any engine I build that is not all stock gets balanced, even stock rebuilds I try to swap pistons around so the heavy ones counteract heavy ones and light ones counteract light ones and same with rods.
Re: Another magnum motor question [Re: HotRodDave] #1182131
02/20/12 08:08 AM
02/20/12 08:08 AM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
Rattler, I did not mean to derail your post. I hope you got the answer you were looking for. Apparently you ask the right questions ahead of your project unlike me. I did personally balance my rod and piston assemblies but it looks like I need to go shopping for a balancer. Thanks Dave.
