Re: Another magnum motor question
[Re: Andrewh]
#1182114
02/19/12 03:41 PM
02/19/12 03:41 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
The serpentine pulley appears to be part of the harmanic balancer, that is why i thought that i might be able to use a regular LA style harmonic ballancer-pulley setup.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: rattler]
#1182117
02/19/12 04:53 PM
02/19/12 04:53 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
I stuck the entire LA front end on the 5.9 I built for my Charger. I used the 318 timing chain cover, LA water pump, damper and all the accessories. I eliminated the mechanical fuel pump and am going with an electric one. I have not started it yet but so far everything looks good to go. I hope to fire it up in the next two weeks.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: dfsmopars]
#1182118
02/19/12 05:44 PM
02/19/12 05:44 PM
rattler
Crofton, Ky.
I haven't decided which intake carb combo to run yet. This will be a mild set-up for the wife. But, back to one of my questions, can i use an early LA 360 balancer?
[Re: BulletBob]
#1182122
02/19/12 09:09 PM
02/19/12 09:09 PM
rattler
Crofton, Ky.
What year balancer would i need Bob?
[Re: Andrewh]
#1182126
02/19/12 10:24 PM
02/19/12 10:24 PM
rattler
Crofton, Ky.
I was looking at online parts sources and it listed 94 thru 03 as one part, and 93 back to 79 as being another balancer. I am just trying to round up the right parts before i need them.
[Re: rattler]
#1182127
02/19/12 10:40 PM
02/19/12 10:40 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
That's correct 93 and back LA 360's used a different balancer (IIRC) than 94+ 5.9 Magnums. That is because the Magnum used a different crank, with lighter rods and pistons than the old 360 LA did. I'd be concerned that bad things will happen if you try and mix/match them.
Are you sure the serpentine pulley won't come off of the Magnum balancer? I'm having a hard time visualizing that the pulley and balancer are one part... (balancer is iron and the pulley, stamped steel)?
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: BulletBob]
#1182129
02/19/12 11:12 PM
02/19/12 11:12 PM
dfsmopars
Kentucky
To use your stock stuff you need a cam snout extension from Hughes. as far as the crank pulley Get you a balancer from a earlier MAG 5.9 & put it on & bolt your pulleys up 1 hole can be burred out to fit the sixth bolt. To use your stock Alt brackets you will need to grind a boss on the head down or move the tab on the bracket
Alright, let me get this straight. With a '94 block, stock crank, KB pistons and an externally balanced flex plate from a Magnum, the LA damper from a '72 318 will not be good? What will happen? Is there a catastrphic imbalance or an annoying vibration? Is it something I can break-in the engine with and change later if I recognize a problem? I have everything put together and you have my gotten my attention.
[Re: dfsmopars]
#1182130
02/20/12 01:20 AM
02/20/12 01:20 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
You are asking for trouble, that thing is gonna be way out of balance.
One...the KB pistons are lighter than stock.
Two the magnum and LA are balanced different on the front and back of the eninge.
When I was 19 I built a 360 once without balancing it and used the KB 107 piston, 360 rods, 360 crank and at first used 360 balancer and converter weight, vibrated real bad and ate HP. I got told to balance it, instead I looked up the weights and figured it would be closer to a 5.9 balance factor, put in a neutral converter a 5.9 plate and damper and it was better but still bad, finnally pulled it all, balanced it properly and no other changes it felt smooth as glass and felt like another 50 HP, so now any engine I build that is not all stock gets balanced, even stock rebuilds I try to swap pistons around so the heavy ones counteract heavy ones and light ones counteract light ones and same with rods.
[Re: HotRodDave]
#1182131
02/20/12 08:08 AM
02/20/12 08:08 AM
dfsmopars
Kentucky
Rattler, I did not mean to derail your post. I hope you got the answer you were looking for. Apparently you ask the right questions ahead of your project unlike me. I did personally balance my rod and piston assemblies but it looks like I need to go shopping for a balancer. Thanks Dave.
[Re: dfsmopars]
#1182132
02/20/12 11:13 AM
02/20/12 11:13 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Rattler, sometime around 2000 or 2001, the 5.9s got a single piece harmonic balancer and crank pulley all cast as one unit. All the parts stores also changed their computer listings for this one piece unit, and will tell you with 100% confidence that it's the exact same set-up as what an earlier 5.9L magnum came with, because that's what the computer shows.
the dealer can still get the original balancer and separate pulley but it's about $120 MORE than at advance auto, and there's a 6 week wait (that's what they told me when I called for one for my 98 dakota)
That said, I have one that's used, and I believe it's in good shape. it's a stock original piece with unknown miles. you could take your V-pulley and oval out one of the holes so it bolts up.
if you're interested, I'll make you a killer deal on it.
**Photobucket sucks**
[Re: dfsmopars]
#1182133
02/20/12 11:17 AM
02/20/12 11:17 AM
70Cuda383
Marysville, O-H-I-O
I know it's not what you want to hear, but you really need to take that assembly down, have a machine shop balance it for you. those KB pistons are WAY lighter than stock, and the mistmatched dampner and flexplate will NOT do good things for you. take it all in and let them get all the parts matched together.
[Re: 70Cuda383]
#1182134
02/20/12 08:59 PM
02/20/12 08:59 PM
rattler
Crofton, Ky.
I may take you up on that offer Tom, this motor came out of a 99 Durango and it has the one peice pulley-balancer.
