paint my engine #1181941
02/19/12 11:38 AM
02/19/12 11:38 AM
meadville, pa
chargerbill Offline OP
meadville, pa
i am building a engine for my 72 charger i want to paint it B5 blue to match the car. the guy that did the engine work said i can paint it with body paint and it won't matter. some are telling me i have to use heat paint. help
Re: paint my engine [Re: chargerbill] #1181942
02/19/12 11:45 AM
02/19/12 11:45 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
As long as the prep is right you should be ok. The local custom guy painted the 396 to match the rest of his chevelle and the paint never flakes off. This was Sikkens paint, really good stuff!
Re: paint my engine [Re: moparpollack] #1181943
02/19/12 04:05 PM
02/19/12 04:05 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Many, many guys on the board have painted their engines with body paint. I think it holds up better than the cheap spray on crap in a can. The block just has to be very clean/free of oil and prepped right, epoxy primer is a must IMO.
Re: paint my engine [Re: DaytonaTurbo] #1181944
02/19/12 04:15 PM
02/19/12 04:15 PM
wellington ohio
68-scatpack-rt Offline
In thin ice
In thin ice
wellington ohio
yep. paint away. the block does not get hot enough to burn off the paint.
unions....the folks who brought you the weekend!
Re: paint my engine [Re: 68-scatpack-rt] #1181945
02/19/12 04:27 PM
02/19/12 04:27 PM
Modesto CA
BFASTER Offline
BFASTER  Offline
Modesto CA
Absolutely correct! A block gets what, 180 degrees? I bake paint at 160 for 40 minutes in the booth. I painted my 440 with some cheapo single stage 'U-Tech' automotive paint 4 years ago and still looks great. Just prep it well and dont put it on too thick.
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: paint my engine [Re: chargerbill] #1181946
02/19/12 05:28 PM
02/19/12 05:28 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Body paint won't come off. I know...I painted my 340 years ago with Omni base and want it off now and it is very hard to remove.
Re: paint my engine [Re: chargerbill] #1181947
02/19/12 05:38 PM
02/19/12 05:38 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
body paint works great. If you decide to paint the intake, make sure you block the heat crossover or it may burn the paint over the crossover.
Re: paint my engine [Re: forphorty] #1181948
02/19/12 07:49 PM
02/19/12 07:49 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
The tech sheet for the paint MAY give the temperature range the paint will tolerate. I've used Rustoleum on the valve covers of my old work truck. It's held up fine. The small print on the paint can said not to apply the paint to surfaces that get over 200 or 210 degrees. You may find the automotive paint manufacturer publishes a temperature range for it's paint as well.
Re: paint my engine [Re: QuickDodge] #1181949
02/19/12 10:38 PM
02/19/12 10:38 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Not only does body paint work,so does bondo. The only problem we've had with bondo was with valve covers next to stock high rise 440 exhaust manifolds. The paint worked next to the heat but the bondo lifted. Keep the primer thin. Etch primer actually works better than epoxy on cast iron. Either one on aluminum or steel. Check out this cross ram. It looked like a cinder block before bondo. It was painted over 15 years ago,still looks good.
Doug
