polishing trim??? #1180596
02/18/12 09:22 AM
02/18/12 09:22 AM
N.Y.
sixpacksteve Offline OP
N.Y.
ok guys this has probably been asked alot and i missed the boat.
ext trim. not pot metal say alum. or stainless has a anodize finish. how do you remove it. and whats the best products to restore it? other than sending it out and waiting 2+ years?
Hell Hath No Fury Like Mine
Re: polishing trim??? [Re: sixpacksteve] #1180597
02/18/12 02:20 PM
02/18/12 02:20 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Stainless trim does not have an anodized finish/protective coating.
You aluminum trim will have an clear anodized coating.
Not the best, but it is affective for a home user to use Easy Off oven cleaner to remove the anodizing. Spray. Let set for 10-20 min. Rinse and scrub off. It will take many applications. And don't let it sit for hours and get to agressive with the base aluminum.
Re: polishing trim??? [Re: autoxcuda] #1180598
02/19/12 11:03 PM
02/19/12 11:03 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Stainless has no coating. File or sand with what ever grit needed to remove the flaws. Sand in opposite direction with each finer grit to make sure scratches are gone. Use heavier grit in damaged areas only to eliminate extra work. Finish with 1500 and polish. Aluminum is anodized which can be removed with lye or sanded off. Same procedure only finish with 800 grit. It is not necessary to re-anodize. Here's my results.
Doug
Re: polishing trim??? [Re: sixpacksteve] #1180599
02/19/12 11:06 PM
02/19/12 11:06 PM
Posting from 1893 in NW FL
TheBlueBeast Offline
You should try and get up member 340six.
kevin is the mad polisher of the general board.
Re: polishing trim??? [Re: TheBlueBeast] #1180600
02/19/12 11:14 PM
02/19/12 11:14 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Kev is kinda out of commission right now.
-Daty
Re: polishing trim??? [Re: Daty Rogers] #1180601
02/22/12 03:06 PM
02/22/12 03:06 PM
Ohio
RonaldV Offline
RonaldV  Offline
Ohio
This is something anyone can do at home. Even if you have a few dents in the trim. Gently hammer them out from behind then file down as straight as possible. Sand out the file marks going from heavy grit to fine then buff out at the very end. You can get amazing results on your own. Get a junker piece of trim to practice on first.
Re: polishing trim??? [Re: autoxcuda] #1180602
02/22/12 03:22 PM
02/22/12 03:22 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
A Moparts member put this together...
http://www.youtube.com/watch?v=wTxR8LB9iek
I'm only linking the first one, there are three, he did a great job making it, you should watch it...
