Hemi & 440 fuel vapor separator question #1180591
02/18/12 08:47 AM
02/18/12 08:47 AM
PEI Canada
chromedome426 Offline OP
PEI Canada
I was wondering about the fuel vapor separator. Is it just an empty canister with a return line, or does it also act as the fuel filter as well?
Re: Hemi & 440 fuel vapor separator question [Re: chromedome426] #1180592
02/18/12 09:16 AM
02/18/12 09:16 AM
Australia
charger RTSE Offline
Australia
Yes It has a screen inside as well.
Re: Hemi & 440 fuel vapor separator question [Re: charger RTSE] #1180593
02/18/12 09:39 AM
02/18/12 09:39 AM
PEI Canada
PEI Canada
Thanks Steve....
Re: Hemi & 440 fuel vapor separator question [Re: chromedome426] #1180594
02/20/12 01:12 PM
02/20/12 01:12 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I would still use a fuel filter. It's a pretty course screen. The return nipple also has a .060 restrictor in it. If it didn't, you would have no fuel pressure.
Re: Hemi & 440 fuel vapor separator question [Re: torkrules] #1180595
02/20/12 01:25 PM
02/20/12 01:25 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
As said, make sure the VS you have has a .060" restriction in the return nipple. It's a fuel filter also.
I have been running them on both my cars and only use them, no other filters other than the sock in the fuel tank. Just like the factory did on 440 6paks and hemis.
My 340 has had one since 2003 and over 15K miles and my 440 since 2005 with a lot less miles. My 340 has been run in all conditions like 110 degrees in Vegas and 32 degrees and 95 degrees(was there twice) at 14100 feet in Colorado. I'm sold on them with a return line. Properly installed they prevent vapor lock. Both of my fuel pumps are mechanical. They would help even more with a electric pump.
Drove my 340 car all weekend and even to work this morning, it was frosty this morning.
