how do I swap a slant six for a 383 in a 66 belvedere i
#1180520
02/18/12 02:23 AM
02/18/12 02:23 AM
Posts: 478 Brady Mt Big Sky Country
72roadrunner
super gas
super gas
I have a 66 plymouth belvedere with a slant six and a 3 on the tree,,, I have a 65 polara with a 383,,, a 23 spline 4-speed and some other goodies I want to put in this car. Do I need to find a k-frame for this car, or does someone make mounts to put it in. What headers to use? Any input would be greatly apreiated. thanks
Conrad Salvage & Recycling 406-278-7909
Re: how do I swap a slant six for a 383 in a 66 belvedere i
[Re: calrobb2000]
#1180524
02/18/12 09:58 AM
02/18/12 09:58 AM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
hi you should be able to do it with a stock 383 mount bracket on pas side i believe and a truck mount bb bracket on driver side i believe !
That works for a smallblock into an A body but that is the first I have heard of doing a big block into anything ...
[Re: JohnRR]
#1180525
02/18/12 11:27 AM
02/18/12 11:27 AM
72roadrunner
super gas
super gas
everything im seeing is for v8 cars to start with. Can I cat the mounts off the polara and use weld them to this k-member? or is that a bad idea. I'm looking for the easyest way,, but want it to be safe too. I plan on about 450 hp,,, and I'm not affraid to use it.
[Re: JohnRR]
#1180527
02/18/12 12:29 PM
02/18/12 12:29 PM
Posts: 905 SD
zrxkawboy
SD
Yes, you need a V8 k-member.
It's Swifty! Swifty, you toad sucker!
[Re: zrxkawboy]
#1180528
02/18/12 01:06 PM
02/18/12 01:06 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
I'd use a '68-'69 or '70 K with the better idler arm.
edit: whoops, I see John already posted this.
[Re: 72roadrunner]
#1180531
02/19/12 03:56 PM
02/19/12 03:56 PM
JohnRR
U.S.S.A.
so any v8 k-member works,,,, small or big block
YES , they are the same , the difference is the metal bracket that bolts to the engine , the rubber mounts are also the same small and big block.
[Re: Joesixpack]
#1180533
02/19/12 06:41 PM
02/19/12 06:41 PM
Or, depending on the car is going to be used, cut off the mounts altogether and go with a Motor plate. I just rode in a BB a-body that had one and it wasn't bad at all!
#1180534
02/19/12 07:39 PM
02/19/12 07:39 PM
72roadrunner
super gas
super gas
I wasn't sure about the k-member because my 73-74 roadrunner, satellites need to be swaped for a big block. Cool, Now i'll see if i can find one
