Radial Tire Pressure #1180196
02/17/12 10:39 PM
02/17/12 10:39 PM
MoreParts Offline OP
I've got a '70 Challenger R/T vert. The biased ply pressure is on the low side for radials. I'm running Goodyear 225/70/14s all around. They're pretty close to the same size as the originals.
What pressures are you guys running?
Also interested in what '74 B and E bodies tire pressure stickers said from the factory with factory radials.
Thanks!
Re: Radial Tire Pressure [Re: MoreParts] #1180197
02/17/12 10:54 PM
02/17/12 10:54 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Thanks!
I use 32 up front and 35 in the rear for my big old station wagon.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Radial Tire Pressure [Re: MoreParts] #1180198
02/17/12 10:56 PM
02/17/12 10:56 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
When I had my Oz Charger and ran Cooper Cobra's I ran them at 32 psi.
Re: Radial Tire Pressure [Re: OzHemi] #1180199
02/17/12 11:05 PM
02/17/12 11:05 PM
Kirkland, Washington
Pacnorthcuda Offline
I too am a 32 psi guy. On everything.
Re: Radial Tire Pressure [Re: Pacnorthcuda] #1180200
02/17/12 11:07 PM
02/17/12 11:07 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..30
Re: Radial Tire Pressure [Re: Pacnorthcuda] #1180201
02/17/12 11:08 PM
02/17/12 11:08 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Hand truck and lawnmower too ?
Re: Radial Tire Pressure [Re: OzHemi] #1180202
02/17/12 11:12 PM
02/17/12 11:12 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
- Stu Harmon
Re: Radial Tire Pressure [Re: MoreParts] #1180203
02/17/12 11:51 PM
02/17/12 11:51 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
I work at a tire shop and have many Mopar clients.
Typical rule of thumb when is whatever the bias tire placard reads,add 6 psi for radials.
If the car calls for 26 psi,go to 32 with radials.
Most Mopars called for 24 psi up front,so go 30 .
Just a couple examples that work well with stock original or restored cars..
Cars that had any suspension or chassis mods or larger wheels & lo-pro tires will have to be set differently to work with said mods..
Hope this helps.
(BTW,yes my wagon is wearing the bias-ply in the first pic,LOL!! )
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Radial Tire Pressure [Re: 68Cbarge] #1180204
02/18/12 12:13 AM
02/18/12 12:13 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Do a smokey burnout!
Full width of the tire, burnt rubber = good contact patch and correct pressure. Too much pressure will leave a narrow burnt rubber patch in the middle of the tire track, while too low pressure will leave 2 burnt rubber streaks on the outside edges of the tire track(s), but nothing in the middle. This is pretty much trial and error, and can vary a lot depending on tire size AND width of the rim.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
