My new Torque plate from Performance only! #1180093
02/17/12 08:10 PM
02/17/12 08:10 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Pictures and an action youtube. I would really like to thank Dan at Performance Only service packaging and shipping all worked out great only thing my machinist complained about is that it is too shinny and lights glare off it! :-) And it is hard to take pictures of
http://youtu.be/mH5IIEMa6rw
Re: My new Torque plate from Performance only! [Re: Dodgem] #1180094
02/17/12 08:40 PM
02/17/12 08:40 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
SWEEEET! Where are my sunglasses???
Re: My new Torque plate from Performance only! [Re: Labratt] #1180095
02/17/12 10:15 PM
02/17/12 10:15 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
That's my machinists complaint to much glare off it! sure is pretty and nice and lite.
Re: My new Torque plate from Performance only! [Re: Dodgem] #1180096
02/17/12 11:14 PM
02/17/12 11:14 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Who would have thought that a torque plate could be pretty? That's one fine looking slab of aluminum!
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: My new Torque plate from Performance only! [Re: Dodgem] #1180097
02/17/12 11:24 PM
02/17/12 11:24 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
.... can I borrow that? Ill bring it right back when im done...
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: My new Torque plate from Performance only! [Re: yella71] #1180098
02/17/12 11:37 PM
02/17/12 11:37 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
BLING
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: My new Torque plate from Performance only! [Re: hemi-itis] #1180099
02/18/12 09:56 AM
02/18/12 09:56 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Nice
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: My new Torque plate from Performance only! [Re: Rapid340] #1180100
02/18/12 02:47 PM
02/18/12 02:47 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Thanks I'll have to make it a wall show piece in the garage once the motor is finished.
Re: My new Torque plate from Performance only! [Re: Dodgem] #1180101
02/19/12 02:49 PM
02/19/12 02:49 PM
Delray beach, Florida
P
Performance Only Offline
P
Barry, thanks for the kind words. i have the same problem trying to get decent pictures of those things. i solved that problem by having some of them hard anodized in different colors. the black has been very popular here locally but red and blue also look great, especially after they're engraved. the hard anodizing makes clean up easier and helps to eliminate scratches too.
sadly i don't have any pictures of those right now i could post. when i do i'll be sure to post them though.
we'll be making runs of the bigblock, smallblock and gen 3 hemi's again very soon. we sold out of every one of those in very short order twice now.
i've been getting a lot of requests locally for the GM LS motors and even a few from Mopar guys.
it's always nice to get feedback, especially from the owner AND his machinist.
machine shop owner and engine builder
Re: My new Torque plate from Performance only! [Re: Performance Only] #1180102
02/19/12 04:52 PM
02/19/12 04:52 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Are torque plates suppose to mimic a cylinder head. What I'm trying to ask is that the head bolts are of different length because of the thickness of the cylinder head. Do the torque plates need to mimic this.
Matt
Re: My new Torque plate from Performance only! [Re: MattW] #1180103
02/19/12 05:04 PM
02/19/12 05:04 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Matt
no
Re: My new Torque plate from Performance only! [Re: MattW] #1180104
02/19/12 05:51 PM
02/19/12 05:51 PM
P
P
Matt
Matt, the torque plate should mimic the distortion of the cylinder walls as closely as possible. the depth of the fastener in the block does influence amount of distortion, that's the reason the bolt holes are countersunk into our torque plates.
i recently test a R-3 block to measure distortion and found .0016-.0017 near the top of the cylinder after bolting on a pair of edelbrock heads. i removed the heads and bolted the torque plate on and the distortion was again .0016-.0017
the use of a torque plate undoubtedly results in round cylinders during the honing process and results in much improved ring seal. better seal, more horsepower.
Re: My new Torque plate from Performance only! [Re: Performance Only] #1180105
02/19/12 06:21 PM
02/19/12 06:21 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
The thread depth needs to be engaged all the way...yes, but he was asking the bolt length I believe. 4 inch 8 inch and such. Make sure the head bolt holes are bottom tapped and clean for full thread engagement.
Re: My new Torque plate from Performance only! [Re: Mopar-Al] #1180106
02/19/12 06:31 PM
02/19/12 06:31 PM
I thought with bling like that only thing you could do with it is put it on a gold chain and hang it around you neck
Re: My new Torque plate from Performance only! [Re: Performance Only] #1180107
02/19/12 10:21 PM
02/19/12 10:21 PM
Locomotion Offline
Locomotion  Offline
Matt
Matt, the torque plate should mimic the distortion of the cylinder walls as closely as possible. the depth of the faster in the block does influence amount of distortion, that's the reason the bolt holes are countersunk into our torque plates.
With the plate bolted on, do you hone with or without the same style head gasket to be used in final assembly? I've seen some manufacturers recommend "not" using a gasket for honing, which I can't imagine why, so I've always told my engine builders to use a gasket.
Re: My new Torque plate from Performance only! [Re: Performance Only] #1180108
02/19/12 10:46 PM
02/19/12 10:46 PM
FL
74-440Charger Offline
FL
Are the plates used in the boring,honing or both operations? "Machine shops" around here don't/won't use plates, not even if I buy it. They say all you need to do is "torque down the bolts under a stack of washers, if I want to go to the trouble". I am still looking for a machine shop!
Re: My new Torque plate from Performance only! [Re: 74-440Charger] #1180109
02/20/12 12:35 AM
02/20/12 12:35 AM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
74-440Charger:
Well, since you're in Florida, just try to see if you can have "Performance Only" do the machining
I'm sure you'll be happy.
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: My new Torque plate from Performance only! [Re: kick_the_reverb] #1180110
02/20/12 12:56 AM
02/20/12 12:56 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
im not buying one till i see skulls engraved in the plate
Re: My new Torque plate from Performance only! [Re: Locomotion] #1180111
02/20/12 12:59 AM
02/20/12 12:59 AM
P
P
Matt
the gasket facilitates the plate and block to move independently from each other, so i highly recommend it's use. i do prefer to use the same bore size gasket as well as the same type that will be run whenever possible.
stacking washers under a bolt doesn't even come close to what a proper torque plate does. i've tested that theory on a number of blocks and it simply doesn't work. I'd probably look for a different shop if i were you.
Re: My new Torque plate from Performance only! [Re: 74-440Charger] #1180112
02/20/12 01:01 AM
02/20/12 01:01 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
and keep looking untill you find one that won't do it without the plate and Performance Only come's to my mind, since he seem's to be in your part of the country.
