World block question #1180015
02/17/12 05:50 PM
02/17/12 05:50 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
My machinist is wondering since the block is Siamese if the air could be trapped and it might be better to put a couple holes in the gasket as seen below to insure no air is trapped??
Re: World block question [Re: Dodgem] #1180016
02/17/12 07:06 PM
02/17/12 07:06 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
normally i would say no being the head gaskets are designed to direct and control coolant flow, however in your case it probably would be a good idea to put a few small holes there to bleed out any trapped air. you'd need three bleed holes right?
Re: World block question [Re: jamesc] #1180017
02/17/12 07:49 PM
02/17/12 07:49 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
no two the head does not have a center hole unless i were to drill it???
Re: World block question [Re: Dodgem] #1180018
02/18/12 12:04 PM
02/18/12 12:04 PM
snook Offline
snook  Offline
Make sure you check the deck oil feed holes. Mine had blind pipe plugs in there where 0.040" restrictors were supposed to be. Don't ask me when I discovered that.
Re: World block question [Re: Dodgem] #1180019
02/18/12 12:09 PM
02/18/12 12:09 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i wouldn't drill anything yet. give world a call first. see what they say.
Re: World block question [Re: rickraw] #1180020
02/18/12 02:42 PM
02/18/12 02:42 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Have you ever tried to call world! LOL!
Over a 1 1/4 years got through once and never received a call back ever!
Even tried e-mails as they said it was best response no responses there either but on got on their sales e-mail list! LOL!!!!
Re: World block question [Re: Dodgem] #1180021
02/18/12 03:30 PM
02/18/12 03:30 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i did talk to them a couple years ago about a bad hemi block. they did return my call.
Re: World block question [Re: Dodgem] #1180022
02/18/12 03:57 PM
02/18/12 03:57 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've called Mitchells, World Products, and got through everytine I've treid I was on thier list for a Compact Graphite Iron block for several years until they decided to not make them I did call to check when it would be ship around three tines a year, got through everytime
Re: World block question [Re: snook] #1180023
02/18/12 04:47 PM
02/18/12 04:47 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Mine had the .040 but we will be putting blocks in Indy heads oil from the back
Re: World block question [Re: Cab_Burge] #1180024
02/18/12 04:49 PM
02/18/12 04:49 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Any thoughts an air being trapped because of the Siamesed bores Cab??
Re: World block question [Re: Dodgem] #1180025
02/18/12 11:05 PM
02/18/12 11:05 PM
I wouldn't worry about it until I thought there might be a problem You can always jack the front of the car way up when the motor is installed and loosen the radiator cap to let any trapped air out, maybe turn the electric water pump on or start the motor to circulate the water to help remove any trapped air
Re: World block question [Re: Cab_Burge] #1180026
02/19/12 02:24 AM
02/19/12 02:24 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
A Hemi racer told me once that when filling with water keep the pump [ electric ] running and it would disperse the air, if you fill then turn on the pump the air would be locked. Don't know , just what he told me. I'm sure water wetter would help also.
