Installing new lifters into a 360LA?
#1179972
02/17/12 03:44 PM
02/17/12 03:44 PM
Posts: 36 Goodyear, AZ
Redleg
Goodyear, AZ
I am getting 16 new Hydraulic lifters in today. Along with break in oil and Cam/Lifter Lube. This is the first time working inside my engine so if I could get some intructions... I have some books to go by but they are using an 5.9 magnum as there example. Also what is the recommendation on pre soaking the lifters in oil. Do I follow the same break in procedure as breaking in a new cam? Thanks for your help Moparts
Re: Installing new lifters into a 360LA?
[Re: can.al]
#1179977
02/17/12 10:51 PM
02/17/12 10:51 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I just did it on my 318 without removing the intake. It is tricky to do on the rear cylinders where there's stuff blocking your view but you can do it. I used that $8 expanding-tang tool that grabs the inner lip of the lifter.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: Secret Chimp]
#1179978
02/17/12 10:55 PM
02/17/12 10:55 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
But I used a magnetic retriever.
[Re: MoparforLife]
#1179980
02/17/12 11:37 PM
02/17/12 11:37 PM
Challenger 1
Cincinnati, Ohio
Mose cam & lifter suppliers don't recommend pre-soaking the lifters any more. Put a good cam lube on the bases of the lifter and light oil on the lifter sides (not cam lube). If the engine has been run and you are just replacing the lifters (for what ever reason) install and reassemble and fire the engine the lifters should pump on there own.
Wonder what the reason is for not soaking them? I always have...not saying it's right?
[Re: RapidRobert]
#1179982
02/18/12 02:31 PM
02/18/12 02:31 PM
Redleg
Goodyear, AZ
OK so I am supposed to soak them or not, Conflicting answers are confusing me LOL
1977 D-150 Warlock 360/727
2021 Challenger T/A 392/M6
Its pronounced Dirte'
