Re: Deck thickness on W8 and W9 heads
[Re: Dave W]
#1179761
02/17/12 11:15 AM
02/17/12 11:15 AM
Posts: 3,456 Out West
408strokerdart
Out West
What is the difference between the W8 and W9 heads when it comes to deck thickness? I know the W8 is a heavier casting but, does it have a thicker deck surface over the W9 head? My reason for asking is, if someone wanted to build a boosted 1800hp small block, which head would be a more durable piece and not have head lifting issues?
Not sure, but here is a bump to the top. FWIW, I just shipped my W8 heads out and was surprised that the total came to just over 75 lbs in minimal packaging. They are not light and I would suspect that they have more material everywhere...including the deck.
[Re: Dave W]
#1179762
02/17/12 12:33 PM
02/17/12 12:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Durability wise the W-8 any day.... it has ALOT more beef in it.... the W-9 was a cross between a W-7 and a W-8 to make a good flowing but light weight head but they can break pretty easy... I had a valve break and damn near cut my W-9 head in half... if you want to see the deck thickness look at the corners or look at a water hole
