440 Dynamic Compression and Pump Gas
#1179422
02/16/12 04:49 PM
02/16/12 04:49 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
I know there's a similar post already on here, but I would like to have someone double check me. I used an online calculator and came up with 8.53:1 DCR. Cam Card Static CR 9.35:1 bore 4.35 stroke 3.75 Here's the actual info after degreeing the cam: Int open - 1* BTDC Int close - 41* ABDC Exh open - 54* BBDC Exh close - 2* BTDC Lobe centerline - Int 109* ATDC Lobe centerline - Exh 120* BTDC How will this be on pump gas? I read that 8.1:1 DCR or so is good. Is mine too high? What's optimum? Thanks
Re: 440 Dynamic Compression and Pump Gas
[Re: Dodgem]
#1179426
02/16/12 07:21 PM
02/16/12 07:21 PM
bobs66440
That will be right on the edge with iron heads so sneak up on the total timing and don't run it lean! Just My
I'm running aluminum Stealth heads if that makes a difference. Sorry, should have mentioned that.
[Re: bobs66440]
#1179427
02/16/12 07:45 PM
02/16/12 07:45 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
Static 9.35 with alum heads , it would probably run on diesel ...
[Re: JohnRR]
#1179428
02/16/12 08:10 PM
02/16/12 08:10 PM
bobs66440
I think kerosene is cheaper, maybe I can use that
This seems to be a pretty good calculator: http://www.kb-silvolite.com/calc.php?action=comp
I think to be accurate you'll need more info than your post has.
Darren
thanks. I used that one and got the same result. I had read that 8.5:1 is high. I realize that 9.3:1 static is low, but from what I understand, the dynamic number is what really determines if you will have detonation issues or not. I'm still on a learning curve so I'm just trying to gather as much knowledge as possible.
[Re: bobs66440]
#1179429
02/16/12 09:41 PM
02/16/12 09:41 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Darren
Generally, 8.5 w/al. heads is as high as I would go.
Right or wrong, I shoot for a static CR that gets me around 180 psi cranking and then dial in DCR with duration.
[Re: 64Post]
#1179430
02/16/12 10:04 PM
02/16/12 10:04 PM
bobs66440
Darren
Right or wrong, I shoot for a static CR that gets me around 180 psi cranking then dial in DCR with duration.
Ok. Where do you think the timing should be in order to avoid detonation?
[Re: bobs66440]
#1179431
02/17/12 12:02 AM
02/17/12 12:02 AM
64Post
Baltimore/Denver
Darren
That's going to take trial and error testing on your part once you get it one the road. It might look something like this: 16 degrees initial, 34 degrees total, advance all in by 2800 rpm.
[Re: bobs66440]
#1179434
02/17/12 09:34 AM
02/17/12 09:34 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
makes a big difference you will be fine!
When I put aluminum heads (that and the intake was the only change) on mine was 11.5 to 1 and gave a dynamic compression of 9.68 and i went from 102/103 octane (had to mix 60% 110 with 40% 93) right down to 93 and it was perfect. Bigger cams allow more static compression but you will be fine!
Last year I ran 11.9 to 1 with a bigger cam came to 9.8 to 1 dynamic and still ran 93
[Re: bobs66440]
#1179437
02/18/12 03:07 PM
02/18/12 03:07 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Using the Kb Calculator: Entered these specs: Cylinder Head 79cc Piston Head 20cc Gasket thickness 0.040" Gasket bore 4.5" Bore 4.35" Deck 0" stroke 3.75" --Calculated compression ratio = 9.349:1 Rod length 6.768" (440 length) Intake Closing point @ 0.050 = 41 + 15 per calculator instruction = 56 degrees after BDC. Dynamic = 7.911. That should be a cranking pressure of about 156 psi?
The advertised duration numbers look large for that cam? I'm guessing they were measured at 0.002" lobe lift? I think the true intake closing point may be more than the 56 degrees so the DCR and cranking pressure may be lower than the calculated value?
[Re: 451Mopar]
#1179438
02/18/12 07:24 PM
02/18/12 07:24 PM
bobs66440
The actual specs of the engine are:
Heads 82cc bore 4.35 deck .085 piston (flat top) 0cc stroke 3.75 gasket .027 gasket bore 4.38
I never saw the "add 15*" notation on the calculators I used. But, I found this page however that has a lot of good info and I entered the actual cam numbers into the calculator downloaded from there to figure the exact intake closing. http://www.chevytalk.org/fusionbb/showtopic.php?tid/92966/
Based on that it turns out to be 71*, which yields a 6.99:1 DCR
That should be pump gas friendly...it should run good on 87 octane...though it may be a slug...
[Re: 451Mopar]
#1179440
02/19/12 02:55 AM
02/19/12 02:55 AM
Posts: 62 montreal, quebec,canada
7e5dartsport
from the cam card, i see you calculated dynamic compression ratio (dcr) from .050 duration numbers . you cannot do that. you need to use advertised numbers. from the advertised duration and max lift degrees (both on the intake) , i calculate the intake closing point is 70* abdc ( 109 + 282/2 - 180) . using this (70*) and the other engine specs you stated, gives me the following results : static cr is 9.35:1, dcr is 7.13:1 , and cranking pressure is 137 psi, which, in my book , will be fine with 91 octane. in my opinion, you will need as much as 37-38* timing
fully legal sounds the same as full illegal...
[Re: 7e5dartsport]
#1179441
02/19/12 03:39 AM
02/19/12 03:39 AM
bobs66440
Thanks for the info. I'm still learning.
I was just curious, how you came up with the 7.13:1 dcr. Originally, I input 110 ICL by mistake, that's how I got the 71*. Using the calculator I have with this 70* info, I come up with 7.054:1?
Not that it really matters that much, just struggling to understand.
