Where do you draw the line with stock 8-3/4" axles?
#1179393
02/16/12 03:53 PM
02/16/12 03:53 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
..... And am I close to that line? Strattling the line? Over the line?
Here's the particulars: Full weight (3775# with me in the seat) '67 B-Body. Street / Strip car, running 255/60 drag radials. 451 / 727 combo, footbreaking. Ran 12.0's last year with a 1.70 short time. A few mods this winter should put me in the 11.80's and maybe 1.68 60's (??).I'd like the car to eventually run solid mid-11's.
It has a fresh center section with 3.91's and an Eaton clutch sure-grip unit. The stock axles looked fine with no visual evidence of twist when I had it apart in the fall.
So where do I stand?
Re: Where do you draw the line with stock 8-3/4" axles?
[Re: reknapp52]
#1179395
02/16/12 04:20 PM
02/16/12 04:20 PM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
My dads 67 satellite has been 11.70's 1.56 60 foot with stock axles.. Only broke one and it has a spool in it. Its getting mosers soon.
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
[Re: kissmyaspen]
#1179396
02/16/12 05:41 PM
02/16/12 05:41 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
How often to you plan to race ? I ask because if you are like me and just do a few T & T races or some local races which for me is about 2 to 4 times a year I might race my 63. This year I had it out 3 times running high 10's and you know I have raced my 63 a few times a year since 2006 and even the old eng ran mid 11's. My point is my axles still look fine with no twist at all on the splines. I am seriously thinking I may want to go to a Dana now that it has run 10.70's and I hope to drop that et some but the rear is still holding up. Course if I raced alot I would not hesitate to go to a Dana. But if you only race a few times a year you may be fine in a mid 11 car. And I am using a Detroit Locker with stock axles. Course it will never hurt to upgrade because if the rear does break you best pull the trans and check the overrunning clutch if its an auto. Ron
[Re: StealthWedge67]
#1179400
02/16/12 08:13 PM
02/16/12 08:13 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
How much racing are you planning on doing ? the better you 60 ft the bigger the chance of twisting the axles , luckily with an 8.75 the axle will not exit stage left when the end twists off .
I'd think about changing when funds allow.
[Re: JohnRR]
#1179401
02/16/12 09:04 PM
02/16/12 09:04 PM
StealthWedge67
Puyallup, WA
You guys bring up a good point: I'll only race 5-6 times a year if I'm lucky. Sounds like the consensus is that I'm fine for now. I'll make a point of checking the axles each winter, and spend the money on something else.
Thanks as always, guys.
#1179402
02/16/12 09:13 PM
02/16/12 09:13 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
On the edge
Maybe the Sure Grip will help save them (I have a locker) but my 67 broke an axle the day I dipped into the 11's.
I had 4 passes that day, a 12.2, two 11.97's and a 22.42. Guess which one the axle broke on
Replace the axles, when the stock axle breaks you'll be looking at possible trans (sprag) problems too.
JUST DO IT......
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
[Re: Mopar-Al]
#1179405
02/16/12 10:06 PM
02/16/12 10:06 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
I've heard of a fair amount of aftermarket axles breaking lately in applications they shouldn't. You might be better off with known US made steel axles (stock ones), even if they are 40 years old.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Rapid340]
#1179406
02/16/12 10:37 PM
02/16/12 10:37 PM
Posts: 429 Sherman Texas
The Shocker
Sherman Texas
One of the hardest things on axles (especially stock axles) is not the hard launches it is running a spool IMO.I broke many stock 9 inch Ford axles in street cars running a spool on the street (and sum of them never got raced on a track).What i mean is people run a spool for a while and twist the axles ,and the first time they get a good launch they snap and people assume the launch is what broke the axle when infact the axle was already weak from the sharp turns with the spool.I got so good at changing them i would pull the other side axle out and then run a long dowl rod to knock the broken piece of axle out .Then i would run a broom handle with a magnent taped to the end down the axle tube to retreave the piece .I could change the axle without dropping the chunk out this way and be back on the road (hey i was a teenager ,lol). They all twisted off right past the splines and i broke the biggest part of them on the left side .The reason the left side breaks most is because of the sharper turns that take place to the right on the street.My Dart drag only car has an 8.75 and im running a spool and 35 spline Moser axles ,but im still easy with it and take 3 point turns off the trailer ,onto the track ,etc when i can.I also inspect my axles for signs of twist at the end of each season ,but the 35 spline Moser's are still straight as an arrow after 5 seasons now ...
[Re: The Shocker]
#1179407
02/16/12 11:00 PM
02/16/12 11:00 PM
Posts: 553 Kentucky
clovis
Kentucky
My 8 3/4 has probably 300 passes on it with stock axles and a spool. I'm about 3400 lbs, footbrake and ran high 10's-still has no signs of twisting. With the new motor I went ahead and put a Dana in, as the difference in price when starting at ground zero is pretty nominal.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: clovis]
#1179408
02/17/12 12:14 AM
02/17/12 12:14 AM
Triple Threat
Renton Washington
We raced my dads challenger for lots years with stock axles, Heavy car, went 1.63 best and 11.90's. Never hurt the axles.
You SHOULD be fine.
