Head flow = horsepower #1179221
02/16/12 01:52 AM
02/16/12 01:52 AM
MN
dustyswinger Offline OP
MN
Last year one of my heads sprung a leak and I think it's time to upgrade. I have a stock block 416 with a mechanical cam 265@.050 with 600 lift, 11.25 to 1 compression, factory cast iron heads that flow 271 and 171, a 1 7/8 headers, victor 340 intake and a 950 hp carb. My question is what should i pick up going to a set of ported edelbrocks that flow 299 and 218 and a super victor. My motor made about 515 HP and touqe before the change. Im looking for reduced ET.
I can also get a roller cam set up The specs were 260/266 degrees duration at 0.050 and 0.683/0.657 lift but I think that would be a little too much for a stock block.
What do you guys think? Thanks Craig
Re: Head flow = horsepower [Re: dustyswinger] #1179222
02/16/12 08:05 AM
02/16/12 08:05 AM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
If your going to go roller use indys and i would say a 100 hp gain. I personaly went from the indybrock and a soild lift cam with your same intake and carb to a roller ,indy-1's and there intake and picked up 8mph but the intake and heads are cnc'd.
Re: Head flow = horsepower [Re: dustyswinger] #1179223
02/16/12 09:26 AM
02/16/12 09:26 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
What dose your car run now, and what ET are you shooting for?
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Head flow = horsepower [Re: dustyswinger] #1179224
02/16/12 11:03 AM
02/16/12 11:03 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
fyi your not gonna need a r block for 600 or 650hp...it is nice to have,but not a must. there strong not like 440 blocks
Re: Head flow = horsepower [Re: fishy340] #1179225
02/16/12 11:26 AM
02/16/12 11:26 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I would guess about 3 tenths gain. I don't think standard edelbrocks are the best choice for you but they will work for an economical stand point. You'll gain a little compression also.
Re: Head flow = horsepower [Re: viperblue72] #1179226
02/16/12 12:32 PM
02/16/12 12:32 PM
MN
MN
I have a cam motion cam right now. That lift is alot to me too. The car has run the best of 10.43 at 127 but normally runs 10.50-10.60 and 126. It 60' in the 1.38-1.43 range. I am trying to get 10.20 I think with just the heads I would get there. With the cam who knows. Thanks Craig
Re: Head flow = horsepower [Re: dustyswinger] #1179227
02/16/12 12:47 PM
02/16/12 12:47 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
What does your car weigh?
Re: Head flow = horsepower [Re: rt66jim] #1179228
02/16/12 01:32 PM
02/16/12 01:32 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
Basic rule of thumb for HP "POTENTIAL" is (cyl head flow at 28") x .257 x (number of cyls). Many high end builds can exceed this, milder combos will never reach it.
Be a Rebel- Break the Laws of Physics!
Re: Head flow = horsepower [Re: mbogina] #1179229
02/16/12 02:29 PM
02/16/12 02:29 PM
MN
MN
3165 with me in it
Re: Head flow = horsepower [Re: dustyswinger] #1179230
02/16/12 06:28 PM
02/16/12 06:28 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well 40 lb off with aluminum heads thats .04 to start and an easy .26 of in HP gain!
Re: Head flow = horsepower [Re: Dodgem] #1179231
02/29/12 02:54 AM
02/29/12 02:54 AM
MN
MN
I ended up buying the whole deal and deceided to put a steel crank and set of rods in it and let it buck. I'm kind of on a budget here and have found a scat crank for 640, a K1 for 689 and BPE has them for 629. Any opionions on these cranks? Just looking for a decent product for the best price, just like everyone else. Thanks Craig
Re: Head flow = horsepower [Re: dustyswinger] #1179232
02/29/12 03:10 AM
02/29/12 03:10 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
All good crank's, but I were to do another smallblock I would go with a BPE just because Rod is a really good and standup guy and has thought his product out.
Re: Head flow = horsepower [Re: dartman366] #1179233
02/29/12 11:39 AM
02/29/12 11:39 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Re: Head flow = horsepower [Re: S/ST 3040] #1179234
02/29/12 12:28 PM
02/29/12 12:28 PM
SoCal
Brian Hafliger Offline
SoCal
I'm looking forward to seeing the results!
Brian Hafliger
Re: Head flow = horsepower [Re: dartman366] #1179235
02/29/12 03:34 PM
02/29/12 03:34 PM
BPE Offline
BPE  Offline
I might be a little biased but I would get one from BPE. Sorry I couldn't help myself.
Rod
Re: Head flow = horsepower [Re: S/ST 3040] #1179236
02/29/12 05:43 PM
02/29/12 05:43 PM
Canada
onig Offline
onig  Offline
Canada
Cylinder heads and HP
Link does not work.
69 Dart
Re: Head flow = horsepower [Re: onig] #1179237
02/29/12 06:38 PM
02/29/12 06:38 PM
S/ST 3040 Offline
S/ST 3040  Offline
It should work now. Maybe an I-phone can't do everything.
