Is This Duster Body Panel Available? #1178836
02/15/12 03:12 PM
02/15/12 03:12 PM
Nanaimo, B.C.
GwaiiEagle Offline OP
Mannix
Mannix
Nanaimo, B.C.
The photo is of the area just in front of the drivers rear tire.
Is this area available. or is it part of the rear quarter panel?
Re: Is This Duster Body Panel Available? [Re: GwaiiEagle] #1178837
02/15/12 03:19 PM
02/15/12 03:19 PM
Bellevue,Mich.
Dodge33 Offline
Dodge33  Offline
Bellevue,Mich.
This is part of the rear quarter,once you remove the outer skin,
you are gonna have a rust hole in the inner structure also.
Re: Is This Duster Body Panel Available? [Re: Dodge33] #1178838
02/15/12 03:32 PM
02/15/12 03:32 PM
Nanaimo, B.C.
Mannix
Mannix
Nanaimo, B.C.
So which panel is required? Is there one available?
Re: Is This Duster Body Panel Available? [Re: GwaiiEagle] #1178839
02/15/12 03:40 PM
02/15/12 03:40 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
They dont sell a patch for it but AMDs full quarters will have the section. Depending on how far the rust goes you may need the rocker panel too.
Re: Is This Duster Body Panel Available? *DELETED* [Re: AdamR] #1178840
02/15/12 03:52 PM
02/15/12 03:52 PM
Nanaimo, B.C.
Mannix
Mannix
Nanaimo, B.C.
Post deleted by GwaiiEagle
Re: Is This Duster Body Panel Available? [Re: GwaiiEagle] #1178841
02/15/12 06:19 PM
02/15/12 06:19 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
The rocker panel goes all the way back to the wheel house. Then the quarter panel is put on over the rocker. So both layers of metal are rusted out. You can fabricate a patch for the rocker because the quarter panel will cover it when complete.
Re: Is This Duster Body Panel Available? [Re: Dave Watt] #1178842
02/15/12 09:19 PM
02/15/12 09:19 PM
Nanaimo, B.C.
Mannix
Mannix
Nanaimo, B.C.
That makes sense, thanks!
Re: Is This Duster Body Panel Available? [Re: GwaiiEagle] #1178843
02/16/12 02:18 AM
02/16/12 02:18 AM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
This is what it will likely look like when you cut the quarter skin off. This was replaced with a used section but I don't have a pic after it was done.
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: Is This Duster Body Panel Available? [Re: MOBodyman] #1178844
02/16/12 02:43 PM
02/16/12 02:43 PM
Nanaimo, B.C.
Mannix
Mannix
Nanaimo, B.C.
Are you on your own with inner wheel well, too?
Re: Is This Duster Body Panel Available? [Re: GwaiiEagle] #1178845
02/16/12 11:49 PM
02/16/12 11:49 PM
Jacksonville Florida
elitecustombody Offline
I was giving a quote to a customer few days ago on Dart,I can tell you that AMD had inner and outer rockers for Dart,most likely they are the same for Duster
Re: Is This Duster Body Panel Available? [Re: GwaiiEagle] #1178846
02/17/12 03:38 AM
02/17/12 03:38 AM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
I can't remember if they offer the inner wheel well but I used a new outer one on this car.
Also remember the rusted out part in the above pic is actually the OUTER rocker. It's just stepped down and the quarter skin goes over it.
Dallas
Re: Is This Duster Body Panel Available? [Re: MOBodyman] #1178847
02/17/12 03:55 AM
02/17/12 03:55 AM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
Here's a pic of the outer wheelhouse. It was an AMD piece and fit nicely. The quarter skin and the trunk extension were older Goodmark parts and required quite a bit of massaging to make them work.
Dallas
Re: Is This Duster Body Panel Available? [Re: MOBodyman] #1178848
02/17/12 02:05 PM
02/17/12 02:05 PM
Nanaimo, B.C.
Mannix
Mannix
Nanaimo, B.C.
This is good stuff.
I picked up the Paintucation dvd on panel replacement and am itching to start cutting.
So far I am stunned at how much Bondo is on the back of these quarters.
